urgent engine oil question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k20, Jan 22, 2003.
  1. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    ok, i just got my truck back and it was quart low so i added some (im running 10w-40 btw) and so i grabbed oil off the shelf in our garage and poured it in. As im puttin the cap back on the empty bottle i notice its 15w-40 and in little print at the top it says engineered for diesel engines, should i drain it and refill it, or just not worry?
  2. oatsk5
    oatsk5 1/2 ton status Premium Member GMOTM Winner
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    there only dif in the two besides there weight is that the desil oil has a better anti foaming agent its not gonna hurt in that sense but the mixing of the 2 weights is ?able its up to you id let it go if you dont drive it alot but thats my opinion /forums/images/graemlins/thumb.gif
  3. evilandangry
    evilandangry 1/2 ton status
    Dec 29, 2002
    105
    Norwood, NJ
    There should be no problem with the heavy oil.... Unless it gets very cold (10 deg or less) even then there should not be a big problem, it is mixed 6:1 with other oil. If you are worried next time put in a quart of 5/30 just to even it out. /forums/images/graemlins/smirk.gif
