Urgent help needed, on a truck issue...
Discussion in 'The Garage' started by sled_dog, Feb 2, 2007.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Sorry that i am double posting this but I really need some input.
    My Dad's friend sprung a bad oil leak and a misfire on his 1989 Bronco II. I looked and determined that it seemed to be the intake gasket. So I pulled it apart, through an intake gasket and a few minor things I saw along the way in the truck.
    Well I put it all back together and now it won't start. I figured, maybe I stabbed the distributor wrong, or maybe the plugs are fouled from oil getting in the cylinders. I did a compression test and all the cylinders seemed decent for a 130k engine (150psi all around). Anyway, I was cranking and cranking, no backfiring, just a little puh puh puh out the exhaust. Then suddenly it popped once. It popped the PCV and the dipstick right out. So it built crankcase pressure or directed pressure down there somehow.
    Any thoughts on this? The guy would like to pick it up tomorrow and I'm scratching my head...
    Been at it, getting the damn thing done for the last 5 hours. Shouldn't have taken me this long and I always hate those jobs and want them gone!
    It is 1:30, my brain is fried, and I'm tired. I have to be at work at 8am to work on yet more cars, so I just need a break from thinking. I haven't even checked for spark yet. Any input is appreciated.
  2. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Well, obviously first problem is that it's a Ford Bronco II...:laugh: :p:
  3. JanneB
    JanneB Registered Member Premium Member
    Dec 9, 2004
    62
    5
    Finland
    Distributor too early, backfire cause pressure in the intake manifold and so on.
  4. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    I know it's too late to help you, but it sounds like the cylinders got washed down, flooded...
    pull the plugs, replace or clean, squirt a teaspoon of marvel in each cylinder, reinstall...
