Urgent help needed
Discussion in 'The Garage' started by k20, Feb 20, 2004.
  1. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Hey guys, where is the fuel pump fuse located on a tbi truck? Wiring diagrams say it is between the distribution block and the fuel pump relay on the firewall, but i cant find it, where is it, thanks.
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    isnt it on the passenger side firewall behind the plastic cover?
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Behind what plastic cover? There is the relay itself on the pass side of the firewall and it is plastic. Or on the drivers side there is a rubber or soft plastic sleeve that holds wires up its about 6" long, its over the booster, is it in there?
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    black plastic covet thats shaped kinda like a T between the block and the heatercore. held on with 2 or 3 plastic nuts
  5. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    I was thinking of the black plastic relay cover. I was also thinking of the fuel pump relay.....sorry. /forums/images/graemlins/thinking.gif
  6. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    your post intrigues me, I dont recall seeing this on my truck, got a pic? And are you sure you arent thinkin of the 2 relays that are above the heatercore in height, but between the block and the heatercore? Theres 2 relays hangin there, and the bracket that holds them is held on w/ 2 sheetmetal screws.
  7. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    what are ya working on?
  8. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    well, I put a Edelbrock MPFI system on was supposed to change the fuse to a larger one for their pump, well stupid me forgot that, today took it for a test drive, shut it down, worked some more, tried to refire, nothing. Then noticed pumps werent workin. Checked pressure, nothing. Then I hooked 12v direct to the fuel pump relay via that little red pigtail on the wiring harness, and the pumps run. That pigtail bypasses the fuse so I know its the fuse, I jsut dont know where it is. BTW if you talking about vehicle its a 87 Chevy K/V20 came w/ a 350, now its got a 496.
  9. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    very cool project. the reason you cant find the black plastic cover is because you are working on a V series, we assumed you were working on the new body style. sorry I have no idea where to find the fuse on the R/V series....surely somebody out there has one of these and can help??????
  10. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Ah, that would make sense, for some reason I thought i had put 87 in my orig post *hits head on table*
  11. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    No worries.....anybody know where the fuel pump fuse is on a R/V series??????????????????
  12. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    If you have something that bypasses the fuse, can't you wire in an inline fuse?
    Or maybe you want to do it right hahahahah /forums/images/graemlins/laugh.gif
  13. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Ive really thought about doing that, but I hate working on a bastardized wiring harness (previous owners suck btw). So id RATHER do it right, but I have not a clue where this danged fuse is.
  14. frankin5
    frankin5 Super Mall Crawler Premium Member
    Oct 15, 2002
    883
    114
    chico,calif
    fuel pump is powered by the 10 amp ecm b fuse in the fuse block under the dash. /forums/images/graemlins/k5.gif lower left side next to turn signals
  15. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    if you are right I owe you an eternal debt of gratitude, im off to pull that fuse
  16. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    i love u man! /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
  17. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Just confirming what Frankie said, but when we put in our MPFI I don't recall changing any fuses, but we did have to change the fuel pump to the pump used in the late model Vortec engines. I would show you some pics of our set up, but at the present time it is so covered in mud, I am surprised it runs. It has performed flawlessly for almost 2 yrs and I am crazy about it.
  18. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    See edelbrock, when you have dual tanks gives you ANOTHER pump, so you end up w/ 3 pumps /forums/images/graemlins/eek.gif So i guess with 3 pumps, you pull more than 10 amps lol. But if I had single tanks, then I would have gotten 1 new pump and it would have gone in the tank. Go figure.
