Urgent help with crankshaft key
Discussion in 'The Garage' started by bigburban383, Jan 10, 2004.
  1. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    What vehicle would I order a crank key for a 383 crank. Or is the key the same as a 350 crank.
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    is it a GM crank ? would be a stock 400 crank then, get casting number from crank, or just get one for a sbc 400, theyre all the same im sure.
    good luck
  3. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    i to am fairly sure they are the same.
  4. Tshane
    Tshane 1/2 ton status
    Nov 26, 2002
    144
    Peoria, Illinois
    All small block woodruff keys are the same. So a 350 will work fine
