Urgent: Need help on Chemistry Problem - UPDATED PROBLEM ON PG 2
Discussion in 'The Lounge' started by colbystephens, Jan 30, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    Help! we're going over Hess's law. how is q=mass x specific heat x change in temp. related to the change in enthalpy of the reaction? this shouldn't be a hard concept for me - but i just can't seem to make the connection. :o can you help??
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    no :) i'm dummified
  3. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Fun stuff Im doing the same exact thing in my chem class. What is the problem...
  4. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    the question is how do you relate q to delta H where delta H is the change in enthalpy of the reaction.
  5. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Hmm hate to say but Im just as confused as you are. If it was a math problem then Id be all over it but those theory questions get me...
  6. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    /\H is equal in magnitude to heat flow (q) for a reaction carried out directly while the pressure is held constant. I.E., when /\H(system) is equal to H(final) minus H(initial), and pressure is held constant, /\H(system) = q.
  7. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I dont think its gonna help if its not in english.:haha:
    -Harrison
  8. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Don’t know if this will help, but here it goes.
    In a chemical reaction (or in pretty much all thermodynamic analyses) the sum of the internal energy (U) and the product of pressure (p) and volume (V) occur so frequently, that “they” just call that enthalpy (H).
    So basically, H=U+pV
    (not sure if you are talking specific heats where "C sub v" and "C sub p" are defined for pure, simple compressible substances as partial derivatives of the funcitons u(T,v) and H(T,p) where v and p denote the variables held fixed during differentiation.)
  9. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    thanks. actually, i found what i was looking for in that delta H = q/#mol reactant. ;) thanks though!
  10. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Well, just busted into my Thermo book and it just confused me more. Are you talking incompressible or compressible substances?
    The good thing is that you'll (likely) never use this stuff when you get out of school.
  11. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Sorry, sounded like you'd already explored that one.
  12. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    ok. here's another one. "An alloy containing magnesium and another metal, that does not react with hydrochloric acid, needs to be analyzed. You are asked to determine the percent magnesium in the alloy. a) describe the procedure you would use to determine the percent magnesium in the alloy, and b) if the sample were 30% magnesium, calculate the heat evolved if a 5 gram sample were analyzed in that manner."
  13. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Have any constraints on the procedure?
    The simplest way would be to figure out the specific heat of your sample using a calorimeter. Given that, the specific heat of Mg, and the weight of your sample you could figure out what percentage of it is Mg. From that you could figure out the mass of the mystery substance and calculate the specific heat of it. That'd nail it down pretty well if your results were accurate. However, part b of your question leads me to believe you're supposed to break this alloy down chemically or through some other method. If that's the case, I can't help you. I was done with chemistry as of last semester. :woot:
  14. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    well, this is a follow up to a procedure which looked like this:
    1. Mg(s) + 2H+(aq) à Mg2+(aq) + H2(g) ΔH*1
    2. Mg2+(aq) + H2O(l) à MgO(s) + 2H+(aq) ΔH*2
    3. H2(g) + ½O2(g) à H2O(l) ΔH*3 = -285.9 kJ (Given)
    4. Mg(s) + ½O2(g) à MgO(s) ΔH*4
    where, using a calorimeter we determined 1 and 2, and using hess's law we determined 4. so, i would imagine that the question i just posted should go along these lines - which is what i think you were thinking. :) can youhelp me determine part b? i'm having trouble - i need to catch up in class.
  15. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I would if I knew what "heat evolved" meant. Once you've figured out the specific heat of your mystery compound, you can figure out the rate at which your alloy would gain and lose heat, but you have to know how many joules of energy are tranferred to it in the first place. :o
  16. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    hmmmmm. well i gotta go to class now. we'll see what happens.
  17. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    btw - heat evolved is heat produced by the rxn.
  18. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    If you have a set of experimental data I guess you could use your calorimeter constant and other parameters from your lab but if not, you should have been given more information.
  19. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    Man, I do NOT miss chemistry class...
