*urgent Question*
Discussion in 'The Garage' started by Chevy305, Sep 21, 2006.
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    I just picked up a new axel shaft and wheel studs. And I don't have a way to get to a machine shop to press in the wheel studs. Is it possible to hammer them in? Or how about using my impact wrench and washers behind a lug nut to tighten them in?
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    dont pull them through with nuts it will stress the lugs. just hammer them through
  3. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Yup........next question :D
  4. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    Big C clamp and deep socket.
  5. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    Hammer Em
  6. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Thanks guys! :waytogo: :bow:
    As it turns out I bought the wrong studs anyway. :doah: :rolleyes: :mad:
    The one on the left is the new one and the one on the right is the old one. I think I got studs for the front wheels not the rear. :crazy:
  7. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    i would use a c-clap an a deep socket, hammer is a dumb idea. i would also put some lok-tite or anti-seize on the spline too!
    LUKE
    later bro
  8. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I'm curious (and confused) - why do you suggest one of these two things? One is used to make stuff come apart later and the other is to make stuff not come apart later.
    :confused:
  9. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    I was thinking the same thing. When we did mine we used the clamp and socket method, works slick
  10. 85 Jimmy
    85 Jimmy Sheepdog Premium Member
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    i use a brass head hammer
  11. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    3 ways to do it...
    The prefered method is a press of course,since most of us backyard mechanics lack one..:rolleyes:
    I've always used a hammer ,if the axle is out of the housing,or the C-clamp and socket method if its installed..
    I've never had a lug stud break after hammering them in,and I aslo used washers and the nut to draw them into the axle without damage,though I can see how doing it that way MIGHT stretch the stud and weaken it..but lug studs are pretty tough steel,and it takes a lot to weaken or break a new one..:crazy:
  12. 79k20350
    Nov 22, 2004
    7,757
    Ct
    The thing about drawing them in with a nut is that it take a ton of force and greatly weakens the stud, i should know, ive had 3 break on a 6 lug hub:eek1:
  13. savagek5diesel
    savagek5diesel 1/2 ton status
    Nov 20, 2003
    310
    Redding California
    i think the major issue with drawing the studs in with a nut is that the little splines on the studs base, bore out the whole, or grind down the splines (i really don't know), and then they aren't going to hold as well as just pressing them streight. Not a fact though, just what i have heard. I've hammered in more than my fair share of wheel studs and it's not fun. C-clamp and socket sounds like the way i'm doing it next time.
  14. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    I use my shop press, sorry I had to rub it in, I will go now.
  15. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    :angry1: :angry1: Damn you!!
    Are the studs I got for the front or did the guy just hand me the wrong ones?
    BTW i think I will go with the c-clamp and socket method. :D
  16. ct85k10
    ct85k10 1/2 ton status
    Oct 25, 2005
    121
    Charlotte, NC
    it looks like a front stud to me you may also try a vice if you have one insted of the clamp may be more stable
  17. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Thanks for the advice! :waytogo:
    I used the socket and bench vice method and it turned out pretty good. :D :bow:
