urgent question
Discussion in 'The Garage' started by SUPERSUB87, Dec 30, 2006.
  1. SUPERSUB87
    SUPERSUB87 1/2 ton status
    Oct 16, 2006
    463
    TEXAS
    what front axle would an 85 f-250 diesel have on it??? can pick it up cheap.
  2. Uncle Fester
    Uncle Fester 1/2 ton status
    Mar 23, 2006
    229
    Cheyenne
    SHOULD be a Dana 60
  3. SUPERSUB87
    Oct 16, 2006
    463
    TEXAS
    thats what i was thinking.but wouldnt it have a 36" spring spacing?
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I think they come with a Dana 50 twin traction beam front suspension.
  5. SUPERSUB87
    Oct 16, 2006
    463
    TEXAS
    an 85? i read somewhere that some f250's 4x4s cam with d60's. althought the twin beam was a common find. im so confused now.
  6. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
  7. pin_it_to_win_it
    pin_it_to_win_it Registered Member
    Jun 21, 2006
    94
    centeral coast california
    WHY are u waisting your time on a FORD?.......just curious.
  8. SUPERSUB87
    Oct 16, 2006
    463
    TEXAS
    it's not the ford... its the friggin axles i want. if it has a 9 inch rear like i think it does and a d60 i will have saved a couple thousand.:wink1:
  9. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    It has neither, a 9" is a 1/2ton rear end. It's going to be a 10" something Sterling rear and a TTB front axle that has a Dana 44 differential. It's all basically not worth your time, if you are wanting a 9" and/or a real 60.
  10. SUPERSUB87
    Oct 16, 2006
    463
    TEXAS
    yeah. i don't know why i put the 9" down. So which fords did have 60's in them?
  11. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    An F250 won't have a 9" rearend. It will have either a D60 or a Sterling. I'm not sure what year Ford went to the Sterling rearend. Ford never used their 9" axle in anything heavier than a 1/2 ton.
  12. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,614
    71
    Living in a dump, VA
    too bad your not closer i got 9inch stuff out the wazoo...cant get rid of it
  13. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    If you want disc brakes, you need a 1 ton front end. Ford used D60 front axles under some 3/4 tons, back in the 60s. Maybe you could special order a D60 after that, but I haven't seen one under a 3/4 ton past 69 model.
  14. Clod_King
    Clod_King 1/2 ton status
    Jun 7, 2005
    1,094
    Grimsby Ontario
    Man I got a buddy up hear that would kill for a couple ford 9"ers.
    But again, I live in Canada, too far away. He has a couple of camaros he wants to put them under.
    I don't know he just doesn't go with the 12 bolts??
  15. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    C-clips are a bad thing, and all the eliminator kits leak out the axle tubes. Just pull a rearend out of a mid 70s 1/2 ton Ford pickup-there's your 9 inch.
  16. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Any Ford F350, from sometime in the 70's up until the late 90's, and again from 2002ish to current.
    Ford had this bright idea to use an oddball D50 front in the early Stupiduties, that would be the '60 gap.
