URGENT
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bking, Jan 16, 2001.
  1. bking
    bking 1/2 ton status
    Jan 4, 2001
    176
    Alaska /Here from Ireland in Dec 2000
    I just got back from the store, K5 running perfect. Went back out 2 mins later and it won't start.
    I have full electrics, but when I turn the key to start it, instead of firing I'm getting nothing, starter? fuse? what? HELP......................
  2. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    my 88 does this sometimes. My ignition key is worn out and wont catch the tumbler some times. Is your key all worn out?
    Bill Innes
    88' Jimmy
  3. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    what do you do if u have a worn out key?
    i think i have one.
    what needs to be done to fix this?
    Confederate's w/ K5's!
    '85 K5: BIG BAD AND MEAN
    K5: Because size DOES matter
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    This happened to me once, turned out that the battery terminal was corrided. 30 seconds with a wire brush and I was on the road. Might also just check the contact of the cables/terminals even if you cant see a massive amount of corrosion(sp?).
    [​IMG]<pre>It's not broken, it's just being maintained</pre>
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Is it an automatic? If so, make sure that it's in park or neutral. If it's a manual, press the clutch pedal (or bypass the interlock switch).
    A bad key would prevent you from turning the ignition switch, so naturally, the starter wouldn't engage. [​IMG]
    I've had this symptom when corrosion built up under the side terminal cable connections. Couldn't see it until I removed the cables. Cleaned out the boogers and it started like a champ. The starter solenoid could also be on its way out. A smack on the starter with a hammer will sometimes loosen it up for a while. [​IMG]
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Try tapping the starter with a hammer a few times. This usually does the trick when they wear out. They take about 30 minutes to replace your first time.
    90K5
  7. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    yeah, just ask dawson......
    am i wierd if i can start my k5 with no key?
    --matt
    shaggyk5: 85 Blazer, 6" lift coming soon!
    Check out the Shag-site: <A target="_blank" HREF=http://www.geocities.com/shaggyk5>http://www.geocities.com/shaggyk5</A>
    nuthin like a heavy chevy!
  8. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    If you have worn out key, you should have a spare, just go get a new one cut. If you don't have one, Have your worn key recut and it might be ok. If it is ok, have a second copy made and keep it as a master.
    <A target="_blank" HREF=http://www.blazen91.coloradok5.com>http://www.blazen91.coloradok5.com</A>
    Protect the land FOR the people
    Not FROM the people
  9. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Hey now!
    Dawson
    88 K5
