USA6x6 inserts... FREE!
Discussion in 'The Garage' started by KRAZIE87K5, Oct 3, 2003.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    THANKS TO DANIEL AT USA6x6 FOR SPONSORING OUR EVENT THIS SPRING! YOU'RE A GOOD GUY IN MY BOOK DANIEL! /forums/images/graemlins/thumb.gif
    I won a $300 GC from USA6x6 at the spring run this year with the Midwest K5 Thing crowd in Arkansas, I decided to use it on these inserts!
    What do you guys think!??? I'll have the choice to keep these and run them - or run a set of magnesium runflats. I'll be running my 42" TSLs with my Hummer rims that should be here in a week or two.
    What would you guys suggest? I often thought I'd run the mag. run flats... because they shouldn't bind with the 42s unless I run something like <4-5 psi.
    So, I'll leave it to you all. What do I do!???
  2. wild-will
    wild-will 1/2 ton status
    Aug 21, 2003
    185
    Oak town WA
    You paid $300 for those? I could have built ya some for 30 bucks
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Read it again! He said he won them. /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/tongue.gif
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Dan, those look like those big plastic pipes they use in plumbing and sewers, etc. True? If so, how thick are they and whats the diameter of them assembled? I may talk to my bro-in-law and see if he can get me some from his work for cheap. /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
  5. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    Dan, As you know I am running my 42's on hummer rims with the mag runflat/beadlock. I haven't experienced a problem so far. The only issue I have trying to get them balanced. Do you have a set for Magnesium runflats already? If not, then use the inserts. However if you do, then I would recommend running the Mag's. I like the way they bolt together better and if you have to you can still run on the wheel until you can get to where you can repair the tire.
  6. o2bjimmy
    o2bjimmy 1/2 ton status
    Jun 19, 2003
    307
    Rapid City, SD
    Resemble is about it, Sewer lines have no business being that thick and new sewer line is green. Water line is blue unless its small stuff, meaning not a water main. Useless info. I know but hey..... what did you expect /forums/images/graemlins/grin.gif
  7. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Here's my only problem man... If I were to air down low enuf to binf one of the tires on the insert, and I killed a tire that way... I'd be ULTRA pissed. Ya know? Nothing like killin a perfectly good 42" TSL! /forums/images/graemlins/rolleyes.gif
    Whats the harm in running these inserts really? Nothing that I can imagine!??? /forums/images/graemlins/confused.gif
    -Dan
  8. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    KO Maybe this is a stupid question but, all that I've heard about these critters is that they're used in Hummer rims that are split, right? So why do these pvc sections come in two pieces per wheel?? Honestly I don't know I'm just curious. Thanks in advance.
    Allan
  9. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I run them in my usa6x6 civilan double beadlocks. They are not regular PVC that you can buy anywhere.. Daniel as them made special for him in 2- foot sections.. /forums/images/graemlins/thumb.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Dan, who moved your centers on your rims, and to what BS did they move them?
  11. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    I have those inserts on my Hummer wheels with 42s. Apparantly he has sold tons of them with no problems so far.
  12. wild-will
    Aug 21, 2003
    185
    Oak town WA
    lol those are 300 bucks normally thats funny
  13. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    There are 8 of them in that pic, so that works out to less than $40 each. Not too bad, really. Try finding PVC that size and see what it costs, then add in the amount of time it takes to cut them up and make the connecting plates.
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No, what's funny is that he doesn't deliver to his paying customers, yet Dan got his for free and on time!
  15. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I don't have hummer rims.. I have civilan beadlocks..
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Oop sorry I meant krazie dan, not you. but your setup is cool too. /forums/images/graemlins/smile.gif
  17. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    As pipe gets bigger diameter, the wall thickness has to go up to support the pressure rating. That is most likely normal schedule 40 PVC. They also make schedule 80 and 120 with even thicker walls. I would bet my Blazer that Daniel DOES NOT have that pipe specially made. 2 minutes on Google get this:
    SCH 40 and 80 PVC specs
  18. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Yeah, if they were custom made they would be one piece, with maybe one opening so you could decrease the diameter with a ratchet strap to get it into the tire and eliminate a point of failure. /forums/images/graemlins/tongue.gif
  19. o2bjimmy
    Jun 19, 2003
    307
    Rapid City, SD
    All i was sayins is Water main line is blue, sewer is green. thats the main. Not pipe coming out of a pumpstation or water tower where naturally you do have to have a beefier pipe. Sewer main is some brittle, real thin stuff. Not pressurized so why make it heavy. Im just talking about the mains, not PVC in some industrial application
  20. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Hmm..I wonder....
    size>>OD>>>>ID>>>>minwall
    16 16.000 14.940 .500
    Cut one crack in it and what do you have?
    Double beadlocks. /forums/images/graemlins/grin.gif
