use lithium grease with polyurethane bushings??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jello, Aug 18, 2000.
  1. jello
    jello Registered Member
    Aug 9, 2000
    36
    seattle washington
    please advise tommorow am I will be installing new shackels and bushings and the installation instructions dont specify the type of grease, do you know ?- and if so why? thanks in advance
    jeff
  2. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    everything I own gets the extreme pressure grease red it handles the highest temps and does not washout.
  3. dumbfounded
    dumbfounded 1/2 ton status
    May 20, 2000
    176
    Castalia, NC
    Most any grease will work. I use marine lube it withstands water and abuse well. It's also high pressure. And you can find it anywhere. They sell kits that come with a pretty trick small "stainless steel" grease gun that won't rust and mine doesn't leak like some other guns I've had. Also it won't turn to a kind of oil if it gets hot like some wheel brg grease. This kind of doesn't matter on bushings but you can leave the gun in the sun and it will still have the same consistancy....
    Love, Peace, and Hair Grease...........
