Used BBC cam
Discussion in 'General Parts for Sale' started by Yukon Jack, Mar 25, 2004.
  1. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    A friend of mine brought some parts over for me to photograph and post for him. He is willing to ship, but buyer cover's actual shipping costs. Shipping would be from Wichita, KS or Derby, KS.
    Cam Dynamics bbc solid roller cam with about 720 lift / 320 duration with a set of crane solid roller lifters. The cam and lifters probably have 10 passes on them . Also a brand new set of GM Performance Parts valvesprings that match the cam. Combined price of $100.00.
  2. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    By the pics of the lifters I guess this is a retrofit setup, not for a factory roller.
    Can you give me some more specs on the cam?
  3. got_mud
    got_mud 1/2 ton status
    May 9, 2003
    316
    Wichita, KS
    Part Number: 19313 Grind Number: 318-322-10R
    Engine Identification:
    Start Yr. End Yr. Make Cyl Description
    1967 Up CHEVROLET 8
    Engine Size Configuration
    396-454 C.I. V
    Valve Setting: Intake .030 Exhaust .030 HOT
    Lift: Intake @Cam 440 @Valve 748 All Lifts are based
    on zero lash and theoretical rocker arm ratios.
    Exhaust @ Cam 400 @Valve 680
    Rocker Arm Ratio 1.7
    Cam Timing: TAPPET @.020
    Lift: Opens Closes ADV Duration
    Intake 57.0 BTDC 81.0 ABDC 318 °
    Exhaust 95.0 BBDC 47.0 ATDC 322 °
    Spring Requirements: Triple Dual Outer Inner
    Part Number 99877
    Loads Closed 220 LBS @ 2.000 or 2
    Open 606 LBS @ 1.300
    Recommended RPM range with matching components
    Minimum RPM 4600
    Maximum RPM 7800
    Valve Float 8200
    Cam Timing: TAPPET @.050
    Lift: Opens Closes Max Lift Duration
    Intake 36.0 BTDC 62.0 ABDC 106 278 °
    Exhaust 75.0 BBDC 27.0 ATDC 114 282 °
    based on the grind number. closest info they had. damn. /forums/images/graemlins/yikes.gif min rpm 4600? guess i don't need that one.
  4. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I'm sorry I didn't see your question sooner, I will check with Jason, I would guess the engine it came from wasn't a factory roller, but I will find out. That is quite an RPM range, sounds like it is fit for a race engine, but not for something we would be likely to run.
  5. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Just heard from Jason and said they are retro lifters and the cam spec's posted look correct to him.
  6. K1Orion
    Jan 8, 2003
    812
    st.louis,MO
    That cam is way too much for me, my truck rarely sees 4600 RPM /forums/images/graemlins/eek.gif
    Would he sell just the lifters and springs? How much $$$?
    Does he have the correct length pushrods? How much $$$ for those if he wants to sell em?
  7. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I spoke to Jason and unfortunately he would prefer to sell as a set. He does not have pushrods for sale. He did say it should be set up to use stock length pushrods.
