Used gears for 14bff install questions
Discussion in 'The Garage' started by GM Man, Jun 19, 2005.
  1. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Would you run the bearings on some used gears that you picked up out of the jy, or should I replace them? I got the carrier with the gears and the bearings are still pressed on. The rollers and cages look ok, and they spin fine. Any issues I should be aware of, before I install the gears this weekend?
    Thanks.
  2. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    Bearings are cheap. So in other words. I would put in new ones. Same for the races. Might not make much of a difference but why shoot yourself in the foot over maybe fourty dollars worth of bearings?
  3. GM Man
    Jan 12, 2003
    549
    Denver CO
    Not to sound stupid, but when I unbolted the pinion gear from the axle housing I left it as one piece with the yoke still bolted on the pinion shaft. If I remember correctly are there three bearings for the pinion gear?
  4. JeffHK5
    JeffHK5 1/2 ton status
    Mar 16, 2005
    544
    Cincinnati
  5. GM Man
    Jan 12, 2003
    549
    Denver CO
    Anyone know of a site or retailer that I can pick up Timken bearings for this??
  6. jhellwig
    May 7, 2005
    420
    Bonaparte, Ia
    Just take the bearing and race (if needed) to any parts store or bearing place and they can cross reference the number.
  7. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    yeah there are 2 bearings in the pinion support and one in the housing itself that supporst the nose of the pinion..
    Chris
