used gears good or bad idea?
Discussion in 'The Garage' started by surpip, Aug 10, 2004.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    im looking to change ratios soon, i want to go cheapest route but i knoe some things arent good to go el cheapo on, anny thoughs, comments?
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    if you get used ones, check for wear such as broken or worn teeth. /forums/images/graemlins/waytogo.gif
  3. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    gears do develope a wear pattern, so it will make it difficult to set them up properly....or so I have been informed /forums/images/graemlins/whistling.gif
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I think I'd go with new gears.
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I would run used in the rear for off-road only (for rock crawling, not desert racing and the like) but not on the street. Front really doesn't matter much, so sure. But it's too hard to get a good setup when they are already worn in. Doubt you would ever match them again. We (well, Brian) had a heck of a time getting my front 4.56s resetup on my Detroit and I would hate to run that on the street in the rear...
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    ok cool so bad i dea to run used gears, at least for me anny way thanks alot,
    dale
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    According to my customers that I ask, they would rather set up used gears than new ones. /forums/images/graemlins/dunno.gif
    For us, the cheapest way to lower gears has ALWAYS been to change to 3/4 ton running gear.
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    you can run used gears if there decent. Not realy hard to set up. We dont really sell used gearsets. But think about it, usually the reason the gears were taken out was probablly because there was something wrong with them to begin with. /forums/images/graemlins/thinking.gif
  9. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    I got a set of used gears one time, came with the amount of shims the last guy used. He only ran them for a bit but I used the same amount of shims in the diff I used and came out with the exact wear pattern. Made for a slick rebuild of the diff. I'm still using them today.
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Or someone wanted to go lower? Or switched to a different axle housing to replace a bent one? Or several other possible reasons...
    First I've heard of anyone preferring to set up used gears, but I suppose it's possible...
  11. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    AHH I didnt realize he didnt want lower gears.
    I never said I preferrd to set up used gears. There not that big of a deal, but I dont prefer it.
  12. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    The "prefer to set up used gears" was directed at Tim's comment.
    And the reasons I listed were examples of where you might find good used gears...
  13. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Hey, I have a great idea for a write up. I'll sell you a perfect set of 4.56 gears for a 14b, you install them and do a write up. /forums/images/graemlins/grin.gif /forums/images/graemlins/thinking.gif
  14. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Gotcha! /forums/images/graemlins/thumb.gif
  15. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    that would be cool but i want to go higher and i need a carrier and i belive theres already a write up about it, but thanks anny way /forums/images/graemlins/waytogo.gif
