used the search but need more info on cummins
Discussion in 'The Garage' started by original balzer, Jul 25, 2005.
  1. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    i have a few questions for a cummins swap. first and formost do i actualy need an overdrive if im running a sm465 205 d60 14b (4.11 gears) and 35-37" tires. whats the rpms at differnt mph. second is the cummins much heavier than the 6.2? it has a 350 in it now but i imagine the 6.2 has to be heavy
    3rd i have been told the 73-87 chevys need either a firewall notch or a 2" body lift to fit a cummins, is this true?
    4th with a cummins would there realy be a need for a doubler?
    balzer
  2. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    I can't help you but you might do some searching at turbodieselregistry.com and dieseltruckregistry.com for cummins swap info
  3. nmaggie99
    nmaggie99 Registered Member
    Jun 24, 2005
    11
    Anchorage, AK
    My owners manual on my '02 lists the engine weight as just under 1100 lbs.. YES a half-ton. Better plan on installing some good springs and motor mounts... :weld: And dito on the the above listed sites.. TDR is the best for info.
