using a 77-78 blazer frame with a 81 chevy stepside
Discussion in 'The Garage' started by 74k5inVA, Jun 24, 2002.
  1. 74k5inVA
    74k5inVA 1/2 ton status
    Dec 13, 2001
    329
    Virginia Beach, VA
    i thought that all the frames for chevy trucks and blazers were the same, but it appears that the stepside wheelbase is about 10 inches longer than the blazer. I thought it would be a direct bolt on. Any comments or suggestions about this would be appreciated. PS-thanks Eads for the great deal on the Blazer /forums/images/icons/smile.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I'd suggest cutting the extra 10 inches out of the front of the bed for a super-shortbed look. I've seen it done before, looks pretty cool. </font color>
  3. 74k5inVA
    Dec 13, 2001
    329
    Virginia Beach, VA
    That's what I told my buddy too, No dice though he's a purist. /forums/images/icons/laugh.gif
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Well, if he doesn't want to do that then he has two other options. #1 - get a Blazer body. #2 - get a truck frame. /forums/images/icons/grin.gif </font color>
  5. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    There is no way to do it I run a 77 cab and 76 or near there stepside bed I cut all the way to the front of the fender and it is still not centered over the tire about an inch off. the frame needs the crossmember for the back of the cab also. I made one bot the truck crossmember should fit if he can get one. check my pics i have a close one notice the step is cut all the way out.
  6. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Angle cut and stitch the frame so it's 10 inches shorter in the rear. Measure carefully so that the axle will look proportioned in the wheelwell. You may have to take a 10" chunk out of the center or X inches out of the center and 10-X inches off the tail so that the axle is "centered" in the wheelwell.
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    I have a bare '85 SWB K10 frame laying in my yard by the garage for sale. It's in perfect condition, too. I have a photo copy of the title for it also.
    PM me if you are interested in this frame instead. /forums/images/icons/wink.gif
  8. 74k5inVA
    Dec 13, 2001
    329
    Virginia Beach, VA
    The Cab bolted right up though. That looks really sweet. Maybe I can talk him into doing that, and then all those extra blazers parts will just be begging to go on my truck!
  9. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Build a custom bed
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    your truck looks good
  11. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    The front is bolt right on the rear you have options I made a crossmember but after the fact found out that the truck frame crossmember goes right in you need the body bushings from a truck for the rear because they are 3" tall. But it is all very easy I have no special mechanical skill and I did it.
  12. 74k5inVA
    Dec 13, 2001
    329
    Virginia Beach, VA
    thanks! maybe i'll go get the sawzall out before he gets off work /forums/images/icons/grin.gif
