Using a shim with zero-rates
Discussion in 'OffRoad Design' started by ZZ4x4, Apr 16, 2002.
  1. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    Stephen, There has been the talk of getting zero-rates machined at an angle for those who need it, but I had a thought and wondered if it might work. Could you first bolt the shim to the zero-rate in the 1.5 offset position, and then bolt this assy to the spring with the hex bolt? I can't tell from the pics whether this would make the shim hang over the edge of the zero-rate which would be bad. If the zero-rate is long enough, it might work. Thoughts?
    Thanks,
    JT
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    It might but I'm not really capable of seeing that in my mind right now since I'm a little screen wiggy (typing for a long time).
    It would also depend on if you're using the offset feature or not.
