using a york as a shop compressor?
Discussion in 'The Garage' started by LKJR, Sep 26, 2004.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    ok so I"ve ran into this delima of not having a shop air compressor, and there seems to be enough times I want one that I'm half-a$$ shopping and trying not to buy.
    basically I want something I can run shop tools with as well as or mostly use a spray gun as well. so do you think a york 210 with a higher rpm electric motor on a big set of tanks would do the trick. I"m thinking I can rig this up for less than or around $100.
    so any thoughts? out of my mind, will it hold up to the amount of abuse for shop jobs?
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i made one for my dad, it was mounted on a 15gal tank powerd by a 5hp gas engine. That was back in 1987. he had to put another compressor on there and a new fan belt. just make sure you have enough oil in it.
    FYI: i ened giving the compressor away to a friend of mine down in mexico about a year ago. i saw him a few days ago and said it was still running. he uses the hell out of it too.
    ARQ.
  3. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    keep the RPM's around 2000 i would think...
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    From what I've read, Yorks do not link to run above 1300 RPM's for long periods of time.
  5. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    wouldn't know why not since they are built to be a/c compressors.... usually running over 2k on the freeway. as long as they have enough oil and there's a filter on the intake.
  6. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Engine may be running at or around 2000 but the pulley size determines the rpm of the pump. Haven't really looked at mine much to figure out what rpm it would be turning relative to engine speed.
