using AC condenser as tranny cooler, any thoughts?
Discussion in 'The Garage' started by ducttape114, Apr 5, 2003.
  1. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    Bec's tube buggy was running this set up at BB. i was really impressed and have been meaning rig it up since i got back. well, tomorow i have a day off so im gonna do it up. any thoughts? advice? experiance? thanks
  2. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    ive thought of the same thing, but was adviced not to do it because it could not take the pressure. im sure other will chime in.
  3. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    A good friend of mine used his AC condenser for a tranny cooler and it worked fine not to mention that it increased tranny fluid capacity by quite a bit. It will work. I wanted to do the same until I got to looking closer at mine and it was cracked. /forums/images/graemlins/frown.gif
  4. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    It should totally take the pressure, A/C pressures can rise up to 300+ psi if it's hot and little air flow. It's good for the extra capacity but I would wonder if it would be too good of a cooler if there is such a thing. It may keep the oil too cold but if you're in a hot climate and the tranny gets used hard, I don't see any problems
    Ben 87 Jimmy + 89 Blazer
    /forums/images/graemlins/usaflag.gif
  5. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I did it on my K/5 but it made the motor overheat. It worked great other then that.
  6. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    I used mine as a cooler for a couple of years before i switched to a 465. Never had any problems
  7. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I forgot all about that. He had a bypass plumbed into the line so he could let the tranny warm up in cold weather and such. That was kind of an after thought. I forgot all about it.
  8. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
  9. 4X4HIGH
    Dec 14, 2001
    22,058
    69
    Pleasanton, CA.
    I have heard that it is not a good idea because any residual freon could kill the tranny pretty quick. I have seen it done before though, but I sure am not going to risk a tranny trying to use one.
  10. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    You run through the both the stock cooler and the ac condensor. The antifreeze will warm the fluid, but the condesor will add more fluid and keep the tranny from overheating.
  11. ducttape114
    Aug 1, 2002
    990
    Orcutt Ca
    thanks seems kind of counter productive. how bad is it if your tranny fluid only gets up to around 100*-110* on the street? thats where its running now.
  12. Itali83
    Feb 12, 2001
    795
    Westbrook Maine
    Oil has a certain temp range it's made to work in. Having it too cold will make it thick, hard on the pump, not burn any moisture out of it, cause harsh shifts and be hard on some internal seals. If your tranny is only running 100-110 degrees now, I'd say thats cool enough.
