using Equal to balance tires
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UNCLE CRACKER, Mar 26, 2002.
  1. UNCLE CRACKER
    UNCLE CRACKER 1/2 ton status
    Dec 29, 2001
    937
    PORTLAND OR
    has anyone used that powder stuff to balance ther tires with? i think the stuff is called EQUAL. ive got 38.5s on 15x10 beadlocks and im trying to figure out a way to balance them . let me know if the stuff works
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    i would like to know too...my beadlocks are a bitch to keep ballanced...
  3. greg83k5
    greg83k5 1/2 ton status
    Nov 2, 2001
    230
    space sity houston, texas
    a laugh was had at my expense when i piped up and said, " you mean like a big jar of sweet-n-lo?".....
    aparently they shake a little coming away from a stop, but when the material gets distributed like it is supposed to, it works great!
    greg
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    shaking at low speeds is WAY better than shaking at high speeds
    ill have to try it to see if it works
    Grant
  5. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Do just a little more checking around. A local shop specializing in dump truck and 18 wheeler tires has some balancing powder that is electrostatically charged. In other words, it uses static electricity to "stick" to the inside of the tire. It will not fall to the bottom of the tire at traffic lights and stop signs. I have not used it or any other balancing powder on my truck. I wil, however,l be testing it out soon. My cousing has balance powder in his 40" Gumbos and it works well for him. I'm not sure of the name of this electrostatic powder. It was suggested to me to try between 8 and 10 ounces of it for my 44" Swampers.
  6. Grim-Reaper
    7,385
    Atlanta
    I know a few people who have tried it. They said it does good. The thing to watch out for is when you air down you want the stem on the bottom so that the powder doesn't get in the valve and cause it to leak.
    There is a thread on BPP of guys putting golf balls in big tires and it helping. Bet that sounds funny when you come to a stop LOL.
  7. UNCLE CRACKER
    Dec 29, 2001
    937
    PORTLAND OR
    let me know the name of that stuff and where to get it. sounds like the awnser to balancing tires keep me posted
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I was never able to get 38.5 swampers that were round.
    I did use equal
    when doing anything valve stem related you must either run the sintered filter stems or give the tire a quick shot of air to clear the stem.
    even to just check air pressure, i killed a guage or two by filling it with powder
  9. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    If any moisture gets in there that powder will be not so great to have. That'd be something that'd make me weary about having it....
  10. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    On a related note: anyone try those Centramatic balancers? They're a plate with a rim aorund the outside of them filled with steel shot. Same principle; it moves to offset the tires heavy spots. Apparently; used alot in the big truck industry.
    Heres the link: <a target="_blank" href=http://www.centramatic.com>www.centramatic.com</a>
    Anyone have any experience with these??
    I'm looking into 42" Swampers &amp; wouldn't mind having some balance in them /forums/images/icons/wink.gif
  11. UNCLE CRACKER
    Dec 29, 2001
    937
    PORTLAND OR
    i called today to get a price on those $200.00 for a set of 4 . man thats alot but if it works i guess it minght be worth it thanks for the info
  12. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    they say you can hardly hear the golf balls unless you listen for it. I'm gonna try these on my 35/15/15 tsl's when i get some time, mostly cause i have an abundance of old golf balls. ill let everyone know how it goes...
  13. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I saw over on an article on the POR Site, that a guy used a shot glass full of BB's in each tire. What do you all think of that ? I'm getting my 38s mounted soon, so I'd liek to know. Thanks.
  14. shaggyk5
    1,610
    SE pennsylvania
    cant confirm this, but i heard that after a while bb's tear up the inside of the tire.
    I dunno.
  15. UNCLE CRACKER
    Dec 29, 2001
    937
    PORTLAND OR
    BBs im still wondering about the golf ball. im going tomorow to get some equal put in my tires ill let you know if it works. i guess they have valve stems to go with the equal that has a built in filter to keep moisture out and to keep the equal from clogging up the vavel stem when airing down. ill keep you guys posted.
  16. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    This is what I was told about golf balls. 36" and under use 2 balls and over 36" use 3 and 42" or 44" might take 4. I think that it might be the only good thing that came out of golf. /forums/images/icons/smile.gif
  17. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    everybody says that if you air up and down the equal will get moisture in it and not work. My 38's have been balanced but still shake a little. Nature of the beast. Just make sure your coffee cup has a lid on it.
  18. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the ones that were available to me were the steel stem with oring seal.
    they wouldnt work on my Eaton rims.
  19. UNCLE CRACKER
    Dec 29, 2001
    937
    PORTLAND OR
    well i put the equal in today and it seems to work very well i also put the knew valve stems in thet have a filter on the end of them to help keep moisture out and to keep from the equal pluging up the valve stem. i used 1 8oz bag per wheel and it worked great i think i moght and some more later on but so far it works great. now my truck wont shake apart going down the freeway
  20. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    what was your final cost for equal in all 4 tires and new valve stems?
