using lowering shackles
Discussion in 'The Garage' started by biglou400ex, Apr 24, 2005.
  1. biglou400ex
    biglou400ex Registered Member
    Feb 5, 2005
    9
    West Taghkanic, NY
    I was wondering if a set of lowering shackles, which i believe are just longer in length to cause the lowering effect, could be used with a shackle flip for a little more lift. Would this cause problems with pinion angle or could it be a cheap way to gain another inch or so.
  2. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    you can do it. you'll probly need to shim your axle down tho, it will affect pinion angle. also most lowering shackles arent very strong from a wheeler's standpoint, might want to reinforce/box them in.
    im thinking about doing this, not to get more lift, but to be able to move the shackle mount forward for a better angle. i think beltech makes a pretty good pair.
  3. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    im using them with 56'' springs i put a piece of 1'' square tubing and im going to box the back of them that should keep them from bending
