Using Nickel99 rods to weld the a$$ end??
Discussion in 'The Garage' started by NITRO, Nov 10, 2003.
  1. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    has anyone ever used these rods for welding the rear end on a truck? ive always used 6011's, but my dad bought some of these to weld a press. they penetrate really deep and are strong as heck. i welded 2 pieces together and then after figuring i messed up, tried to go back and use the torch to cut the weld off and couldnt even cut the weld with the torch. i hadda use the plasma cutter to get it off. so in my book i tihnk they will work. /forums/images/graemlins/thumb.gif thanx guyz
    NITRO
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Whose arse end are you planning on welding?? /forums/images/graemlins/thinking.gif /forums/images/graemlins/rotfl.gif
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    you're closer to him than me so its probably you! LOOK OUT BEHIND YOU!
  4. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Nickel rods are used for welding cast iron, they do penetrate deeper and hold stronger but more $, if you had to weld on the actual differential or knuckles of an axle those would be handy
  5. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    I used Ni-Rod to weld up a cracked cast iron T-case adaptor. It looked ugly /forums/images/graemlins/blush.gif but it held up for over three years until I swapped in another adaptor that had never been cracked.
    I pre-heated the whole adaptor to about 250 degrees, welded the prepped area that was cracked and then after welding I buried it in a bucket of sand and let it sit for 10 hours. It was still warmer than ambient when I took it out of the bucket so it did cool very slowly.
    I don't have a ton of experience with welding cast, but one of my co-workers at the time had done it often enough and told me to do it that way. I can't really argue much because it did hold up just fine...in fact it was still fine when I replaced it.
    The big problem with cast is that it is brittle so it doesn't tolerate the rapid expansion and contraction due to the heat of welding. Pre and post heat helps alleviate that to an extent.
    Rene
  6. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    so dont use them or do?? they are about $3 each, but i have a buttload of them. like i said, they were used to weld a crack in a huge press and i got what is left over. the steel i welded was T1 and that juss would not budge. good rods. but, should i juss use the 6011's or use these? i really like how they weld cuz there is NO splatter whatsoever. its almost like TIG welding.
    NITRO
  7. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    If you're welding cast use em...if you're welding mild or T-1 use 7018, 7014, MIG, etc etc.
    Rene
  8. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
