Using SOAP!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DuneRunner, Sep 18, 2001.
  1. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Today I started to replace the factory rear bushings. I found that drilling the rubber was harder
    than I had planed. I broke 2 bits and tweaked my back a little. After 1.5 hours I finished getting
    only the passenger side of the rubbers off. That's where the SOAP comes in, I put a little down
    the sides of the rubber bushing. I let it penetrate and then the Sledge came out and a Punch.
    BamB Then came the steel sleeves. That took 25 min. Using the most primitive of tools
    (Hack saw, Old drill and a vice, mini sledge and a couple of punches and a little sweat) I was
    successful. Tomorrow I will bring out the Saws All and Do the drivers side the right way...
    Has anyone else done it differently? (I don't have access to a torch)
    Later, KEN
    DANGIT it's not a bronco!
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    My usual method is a dose of something flammable and a match - it's quick and easy to char them out[​IMG]
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    A little Lighter Fluid and a match?
  4. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    That's it[​IMG] Let the rubber soak up the fluid for a few minutes, and toss the match on it - it may take 2 or 3 tries, but the bushing will get small enough it will just fall right off.
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Yeah burning them out is the way to go. I usually use a cutting torch though. But i dont see why lighter fluid and a match wouldn't work.
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze>http://coloradok5.com/gallery/Thunders-Blaze</a>
    <font color=blue>NEVADA: Where the pavement ends, and the West begins.</font color=blue>
  6. shane
    shane 1/2 ton status
    May 6, 2001
    162
    Prince George, BC, Canada
    Sounds like Pugsley should keep a fire extinguisher handy....[​IMG]
    Shane
    Never argue with idiots; They will drag you down to their level and beat you up with experience [​IMG]
  7. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    I can't wait to try it when I get home....
    Thanks Guys.
    KEN
  8. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I do[​IMG] I actually set my workbench on fire doing that once[​IMG]
  9. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    i have never heard that. thats awesome idea.
    <font color=red>K5: Because size DOES matter</font color=red>
    85 K5 4IN LIFT 35 GOOD YEAR WRANGLER MT/R, AMERICAN RACING WHEELS
  10. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    I just removed the stock rubber bushings from all 4 of my springs too (except they were new, to replace them with urethane ones)
    anyways the burning trick crossed my mind but I wasnt sure how well it would work.. Now I know I should have done it.. the bigger ones pounded out well enough but the small ones were a B!TCH!! Took a lot of elbow grease and some serious hits with a hammer but they eventually came out..
    mike
  11. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    ya burning is GOOD is stick my propane torch inside the sleeve and melt away.
    88k5 silverado w4"lift <font color=orange>d44 and corp14ff</font color=orange> with 4.11
  12. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    I put the passenger side back together today. It was a little tight but fits good.
    Started to take apart the drivers side and ran out of day light. Tomorrow I will try the Propane torch. and The lighter fluid trick first, I wanta see if that works It'll Be FUN!
    Q. Should I heat up the small steel sleave that the bolt goes through or should I melt the rubber?
    Thanks guys for the advice...
    KEN
  13. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Just burn out the rubber - after a few minutes of burning, it will start charring, and essentially turning to dust.
  14. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    OOOO YYYAAAAA
    Thanks for the encouraging words to use the Propane torch.
    I heated up the inner steel sleeve. (the one that the bolt goes through) and before you know it. Its out...
    I had to then drill out a little of the rubber. and then hack saw the inner sleeve AGAIN. Thanks again KEN
