Using the spare for rotation...
Discussion in 'The Garage' started by NEK5, Jan 23, 2007.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Well, it`s getting time to buy new tires soon, but I wanted to ask this question. Those of you with a full size spare, are you running a "baldy" (real low thread, but still usable as a spare), or are your running a regular tire (same tread as others)??? The reason I ask, is because I want to find out if it`s worth having a 5th tire that you can use for when you rotate. So instead of 4, you have 5...What is everyone running?
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I have a used tire that is the same as my other 4. I bought all 5 of mine used so I took the worst one and it was designated as the spare. When I go new I will get a 5th as a spare and it will get rotated into the mix with the other 5 to ensure even wear unless I go with Iroks as they are directional and I do not want to break down a tire everytime I rotate. Your spare should be within 2" of diameter of the tires you run.
    Ira
  3. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Yea. Just wanted to see how many out there had a 5th tire, which they added to their rotation...
  4. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Yes, Ben, you bet I have 5 full size tires! Rotation is key to the life of aggressive mud tires, especially TSL's and Boggers!
    Rotation will occur every 5,000 miles. My friend Nick asked me this question the other day: "How are you gonna lift that spare into the bed with a 10" lift?"
    [​IMG] I haven't thought of an answer yet. My bad!
    Manny
  5. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Yep, I've got a full-size spare.... ever wonder about this pic?
    Had a tire at Pismo Beach that wouldn't hold air, so I swapped this "greenie" on there. I had some bright green paint sitting around and figured it would make it easy to locate my tire/wheel if someone decided to "borrow" it out of my truck. :D
  6. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,961
    251
    Released from Pueblo, told I belong in Southpark
    Yep full size spare. How do I lift it. A lot of grunt. 37/12.50/17 krawlers and yes I will rotate it in.
    On my exploder with 31's the spare is full size but different tread so I won't mix it in. Plus its under the vehicle.
  7. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    I have a full size 44 spare that does not get rotated in. it's a baldy and different tread pattern.
    Manny, getting the spare in the back is easy. if you have to do it on flat ground use an 8' 2x4 as a ramp. roll the tire up it. if you can back up to a mound of dirt, a lower pickup, anything then it cuts the angle down greatly. In the field you are going to need a friend to help heave it up there.:crazy:
  8. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Is it worth having a 5th tire to add into the rotation?
  9. DirtyJim
    DirtyJim 1/2 ton status
    May 4, 2005
    665
    San Diego
    get a bald p.o.s. for a spare and rotate the other 4.
  10. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    oh come on ira, nothing like running them backwards for one rotation:haha: i had iroks, got rid of them. next set will be bigger iroks and i think i will rotate them (run them backwards when necessary) rotating the tires really does make a huge difference in the lift of them. swampers dont last that long as it is, i want to maximumize it as much as possible, cuz they are $$$$
  11. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
    I now have 4 full size spares, all good tires. I just keep one in the bed and the rest stay in the garage. So I have 3 35x12.5 r15 BFG A/Ts for sale, if anyone is interested...
    I have gotten 2 flat tires off road and I am really happy to now have an insurance policy if that happens again...
    Now all I need is a jack... :surepal:
