Using van axles on K5?
Discussion in 'The Garage' started by Strahan, Mar 26, 2007.
  1. Strahan
    Strahan 1/2 ton status
    Dec 4, 2001
    251
    Yoe, PA
    I was told that van axles will make the rear tires come out farther so as to match the front ones. If that's true, what years/models van should I be looking for to provide a donor axle? Thanks!
    PS, it's going in an 88 Blazer if that's relevant.
  2. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    True.
    The rear axle from a G30 van has an almost identical WMS to a D60.
    Someone else will need to help with the year range....
    :usaflag:
  3. wforicv
    wforicv 1/2 ton status
    Feb 16, 2004
    165
    Back in Augusta, GA again
    This is from Pirate's "14BFF Bible"
    [FONT=Arial, Helvetica, sans-serif]The 14bolt is found in a huge number of GM 4x4 pickup trucks and vans, 3/4 and 1 ton, from the 70's right through until at least 2000. You can find it in:[/FONT]
    • [FONT=Arial, Helvetica, sans-serif]73-96 C20, C25[/FONT]
    • [FONT=Arial, Helvetica, sans-serif]73-00 C30, C35[/FONT]
    • [FONT=Arial, Helvetica, sans-serif]73-00 G30, G35[/FONT]
    • [FONT=Arial, Helvetica, sans-serif]73-00 K20, K25[/FONT]
    • [FONT=Arial, Helvetica, sans-serif]73-00 K30, K35[/FONT]
    • [FONT=Arial, Helvetica, sans-serif]84-88 CUCV[/FONT]
    • [FONT=Arial, Helvetica, sans-serif]88-91.5 V30[/FONT]
    Here is the link. You will have all the info you need there:
    http://www.pirate4x4.com/tech/billavista/14b_bible/index.html
    My 14BFF came out of a late 80's 1 ton van. -Eric
  4. sweetk30
    Nov 1, 2004
    25,545
    540
    horseheads , ny 14845
    axle swap for you will be 8 lug only unless you want 5 lug rear. as vans werent 6 lug like 4x4 gm trucks.
  5. Strahan
    Dec 4, 2001
    251
    Yoe, PA
    Thanks for the info guys. Eight lug is fine, it'll give me more incentive to swap both axles for full tons ;)
