Utility Interior
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mastiff, Jun 29, 2003.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I've got an 83 K5 and I was wondering what kinds of things people have done to make the interior more durable. In my Jeep, I ripped out all the carpet and Rhino lined the entire tub. I'd like to do something like that with the Blazer, but I'm not really sure what the deal is with the side panels in the bed area. Right now they appear to be some flimsy cardboard or something, and underneath, is it just a a single layer of sheet metal, the same as the outside? That's what it looks like, so you probably need to have some sort of interior side panel in place, or can you just rip all the side panels and carpet out and leave it at that?
    Thanks for any ideas or advice.
  2. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    I took my side panels out and Line-x'd the whole interior, tailgate to firewall and bedsides. Some guys keep their side panels in to hide amps and stuff. They make 'em out of ply (varying thicknesses, but mainly 3/4"), cover them with carpet or paint or Line-x. You can use your existing panels for templates if that's what you want to do.
  3. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Thanks. Without the side panels, could something heavy hit the single ply of sheet metal and dent the exterior of the truck?
  4. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Had the side panels removed and rhino'd everything, from the firewall to the tailgate.
  5. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    The box sides are double walled. You could sledge hammer the inside without ever seeing a mark on the outside.
    Rene
  6. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I removed the stock interior sides and installed aluminum diamond plate (sides, floor and gate). I was going to do the wheel wells and the back of the fold up seat too so the complete rear would be smash proof but I havent finished yet.
  7. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    that a great ideal on the rear side panels..I think I'll make up some new ones and Line-X them...I have just painted wood now and want to chuck them, so I'll cut some new ones and X them... /forums/images/graemlins/thumb.gif
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    without the side panels they look just like pickups, thats cool, ive never seen a 73-up blazer up close.. let alone inside of one
  9. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    That looks great to me with everything ripped out and just Rhino'd.
    I went out and started tearing into my truck. Here's a question: What's the easiest way to deal with that nasty adhesive they used to attach the carpet to the wheel well?
    Also, how in the world do I deal with a rounded out torx bolt? /forums/images/graemlins/confused.gif The big torx bolts holding the rear seat-belts to the bed were pretty tight and sure enough, I rounded the damn thing out. The bit gets no grab now at all, and it would take a ton of torque to get it out even if it was all good. Should I try to drill it or what?
  10. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    same tool will fix the rounded bolt and the nasty adhesive... 4.5" grinder. I used a wire wheel attachment on that adhesive stuff on my rig when I stripped the interior to herculine it (pics in webshots)... and it worked well. standard grinder wheels work good on bolt heads too... just grind that sucker flush if ur gonna line over it anyway.
    j
  11. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    A small propane torch and a putty knife work wonders on the wheel wells and the driver and passenger footwells.
  12. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    I will have to agree that the grinder is the easiest solution to the rubber and the bolt, but since I wanted to keep the possibilities open to re-use the seat belt nuts, I welded a nut on top of the torx bolt and they came right out.
  13. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    j
    What's going on with your fuel filler neck cover thing there (your webshots)? I would have just herculined right over it. Did you remove it, then herculine around it and put it back? Was that just for looks?
  14. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Amazingly, I was able to loosen the bolt by heating it from underneath with a torch and then grabbing it with vice-grips. I never thought it would work. /forums/images/graemlins/smile.gif
  15. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  16. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    The Rhino dealer is talking $650+ to do the whole inside of my K5. I'd do it, but my wife will kill me since she hates my truck. /forums/images/graemlins/frown.gif
    Anyone know a good source for rubber mats for both the bed area and front?
  17. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    You can do it with herculiner for under $100. Someone in my crawling club did it to their jeep and it came out very nice.
  18. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I'm going to go with Line-X on the interior of my K5. The Line-X guy seemed to have much more of a clue than the Rhino guy (he just did an 82 Blazer) and the price was almost half that of Rhino ($350).
    For people who did the entire interior with Rhino or Line-X (or whatever), where did you stop at the front? I've got everything ripped out up to the cardboard stuff on the firewall, so I was thinking of stopping there, but I'm not sure about the floor at the doors. How far out should I go? I could stop at the rubber trim, but the paint does tend to get worn outside of that, so it'd be cool to go further.
    I'm tempted to look into doing the outside of the truck too, like the bottom 12" all the way around (up to the big stripe on my 83 paint scheme), anyone have experience with that?
    Oh yeah, what have people done with the kick panels on each side (the wall area where the people's feet go)? I've got plastic there right now that I'd like to get rid of. On the driver's side this is no problem, but on the passenger side, the vent mechanism is held in by the plastic trim/moulding. Is there an alternative way of mounting the vent stuff without the plastic?
  19. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Here's pics:
    Before:
    After:
    This is just after I got back from the Line-X place, except for the dirty dog footprints. /forums/images/graemlins/tongue.gif
    I've got some more pics here:
    http://www.taildragger.info/K5/index.php
  20. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    how does rhino or lineX stick to plastic? i tried some duplicolor spray on on my door panels and it came out ok but peels easily, but it sticks great on my seatbelt boxes...
