Uuuhhhhh...Did I FUBAR my 14 bolt?
Discussion in 'The Garage' started by afroman006, Feb 2, 2004.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Well I was cuttin the spring perches and shock mounts off my 14 bolt and got to the last spring perch. I decided I could cut closer to the housing so I wouldnt have to grind so much and, well, I cut too close. Look at the pics and tell me what y'all think. The deepest gouge is like 3/32-1/8" deep and if I remember correctly the tube wall is 1/2" thick. So what do y'all think I should do? Leave it alone? Fill the holes in with a stick welder and grind it smooth? Any other ideas? Thx
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    maybe weld and fill? I went pretty far too, not as far as you, but enough that i stopped and thought. I doubt its a structural problem, this worries me in the way of fubar
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Weld it up and grind it down, no biggie.
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I say weld it up, grind it down. Then run a small truss of some sort. A piece of 1.5" 3/16 wall angle layed open side down on the tube should be more than enough reinforcement and a little more piece of mind. I would worry more about a heat distortion issue myself.
  5. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    that's no biggie...you can weld that up and just grind smooth. i with matt on the heat issue though...make sure you don't get the metal too hot while you doing it.
  6. afroman006
    Aug 21, 2002
    2,876
    Ok thx guys. I have another 14 bolt I could rob the housing of if need be but I'll just stick with this one. I'll go ahead and fill it in and grind er down. I dont think I overheated it because I only cut one item at a time then spent about 30 minutes grinding the rest of it down and let it cool then started on another.
