v3500 Brake Hydro Boost??
Discussion in 'The Garage' started by deadeye, Jul 29, 2006.
  1. deadeye
    deadeye Registered Member
    Jul 18, 2006
    35
    Palmetto, FL
    I've never seen one of these in my life. I've always used trans fld for pwr steering fld. Is this still ok with this whacky hydro power boost that runs 'thru' the pwr steering pump, hope I got that right. BTW, I know the master cylinder; it’s the same as any good ole master cylinder.
  2. eeyore
    eeyore Registered Member
    Sep 18, 2005
    47
    utah
    i have one of these and was told by previous owner to run nothing but power steering fluid in it.thats all i have used,but couldnt swear thats right.i did see one in a wrecking yard that had atf in it.
  3. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    i would stay p/s fluid my self. less chances of problems.
    and the master is diffent on the back side for the heavy 3/4 and 1 tons. look close but bigger. stud hole is the same tho.
  4. deadeye
    Jul 18, 2006
    35
    Palmetto, FL
    thanks both of ya, I'm going to stick w/the pwr steering fld then.
  5. sweetk30
    Nov 1, 2004
    25,536
    533
    dont forget to blead it the correct way if it went empty. if you dont know it has been covered before in hear do a quick search.
  6. deadeye
    Jul 18, 2006
    35
    Palmetto, FL
    SweetK30, are you talking about bleeding the pwr steering or the brakes? Did a search on bleed and only found brakes. I know how to bleed brakes, and the way I've bled the pwr steering before is to turn wheels all way left and then right till all the foam is gone.
  7. sweetk30
    Nov 1, 2004
    25,536
    533
    p/s blead out specs. jack up truck. then fill resivor. turn wheel left/right till empty. refill . keep doing till wont take anymore. fire engine no more than 8-10 sec. shut down recheck and fill if needed. when it wont take any more run engine and pump brakes and cycle wheel to make sure air is out.
    these steps help keep the most amount of air out of the system when bleeding .
  8. deadeye
    Jul 18, 2006
    35
    Palmetto, FL
    Got it! Thanks sweetk30!!! The pump brakes and cycle wheel is new to me, kool.
    See my other thread on the mpg? Been a busy morning, but the site has ALREADY helped me a LOT!
