? v6 vortec engine
Discussion in 'The Garage' started by chevystepside, Apr 28, 2004.
  1. chevystepside
    chevystepside 1/2 ton status
    Sep 23, 2002
    147
    leadville colo
    ive got a buddy with a 1994 s10 jimmy with a v6 vortec. it is making a grinding noise at the front of the engine. i thought that it was the waterpump so to verify i removed the serp belt. but the noise did not go away. has anyone had or heard of a problem like this? im going to remove all the accecerys this weekend and remove the timing cover cause it sounds like it is at the front of the engine. any help would be greatly apprecated /forums/images/graemlins/1zhelp.gif
  2. chevystepside
    Sep 23, 2002
    147
    leadville colo
    ttt /forums/images/graemlins/1zhelp.gif
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    check in the timing cover and all. I think those motors have a balance shaft, maybe something got screwed up in it.
  4. dyeager535
    26,979
    I would just make sure that nothing up front is loose. My truck motor made a "knocking" sound that seemed to be getting louder and louder so I eventually pulled the motor.
    From what I could tell after I pulled it, the crank pulley somehow had loosened up, and I *think* the noise was it, as it walked around on the loose bolts as the engine turned.
