V_A_C_U_U_M
Discussion in '1982-Present GM Diesel' started by KRUM, Nov 30, 2002.
  1. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    does anyone have a diagram of the vacuum system?
    reason i ask is i have found some cut vacuum lines(2). first one comes out of the pump & into a T. the line going to the passenger side is cut right at the T. the line going to the drivers side goes into a little box on the firewall & theres an in and an out and when it comes out of there it is cut so my vacuum isn,t really hooked to any thing. i haven't checked to see if i have vacuum cause i have my 700r out & swapping in a T400 any ideas,pictures,sketches would be helpful & i'm still not sure where my vacuum regulator for my T400 goes?
    /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
    thanks,
    Jerry
  2. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    What year is it?
  3. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    87' 6.2 700r soon to be 400T
    thanks,
    Jerry
  4. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    The book I have doesnt show the 87 diagrams! Maybe someone else will be able to you.
  5. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    what does your book have? my hanes doesn't have much
    thanks,
    Jerry
  6. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    I can tell you that the one that goes to the passenger side should go into the firewall and connect to your A/C to control your vents (i.e. Fresh air vent, defrost, etc..) If you have a 700r4 the one going the other way (on mine at least) goes to a double switch, one is the TCC (torque converter control) and I believe the second one controls the valve that opens and closes in your exhaust (right in between the manifold outlet and the exhaust pipe)
    This is the setup on mine, I hope this helps.
  7. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    I have a chiltons it shows 85 and 86.
  8. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    I think one side of the tee goes to the fire wall, the other goes to another tee one part of that tee goes to the epr solenoid the other to the egr solenoid. Both are located next to the vaccuum pump towards the drivers side valve cover. The epr sol. has a line that runs to the epr valve in the exuast, the egr sol. has a vaccuum line that goes to the egr valve. Hope that helps
  9. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    yeah my a/c controls havent worked since i got the thing (wonder why) thanks for the info.i would say the 85 and 56 would be the same?its the silverado package if it matters and i've found like 4 open leaks & i hope my vacuum pump still works.yall know how much those suckers cost?
    thanks a lot guys,
    Jerry
  10. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    I think the cost between $100 and $200!!
  11. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    the line that comes out of the epr sylanoid was cut so i will be replacing it to the valve in the exhaust correct? the egr is already there and the one that goes to the passenger side is my ac controls correct? i still have one more to run down i haven't had a good look at it yet but it has a regular size vacuum line that runs into a T one end of the T isn't hooked to anything but the other has a tiny hose almost like the hose on a mechanical oil pressure gauge any ideas?
    thanks i'm almost
    later,
    Jerry
  12. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    [/ QUOTE ] Yes that is correct.
    [/ QUOTE ] Should be I havent looked at mine yet.
    [/ QUOTE ] I have no idea, could be a gage, wheres the tee located?
  13. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Was this a former California model?
  14. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    THE TEE WAS HIDDEN BEHIND THE VACUUM PUMP AND THE LITTLE HOSE RAN TOWARD THE HEATER CORE AREA BUT I STILL HAVE TO TRACK DOWN WHERE IT CAME FROM.I WOULDN'T THINK SO I BOUGHT IT HERE IN TENNESSEE
    THANKS,
    JERRY
  15. RLBstein
    Jul 2, 2000
    179
    Pensacola, FL
    The little hose that runs to the heater core area is your a/c vent controls. It should hook up to the big black box on the passenger side (on top) and distributes vacuum to the different controls. I think it would be the same w/ a/c or not. Also, what kind of intake do you have. If you have a C-code intake, a vacuum line should go into your air cleaner and plug into a port on top (EGR valve). It's used to open a valve that allows exhaust to flow back into the intake for quicker warmup. It runs from the EGR switch.
