Vac line woes - help!
Discussion in 'The Garage' started by pops83k5, Jul 10, 2003.
  1. pops83k5
    pops83k5 Registered Member
    May 11, 2002
    30
    Basking Ridge, NJ
    My K5 was idling in the drive when it shutoff. It was warmed up ready to go and it died quick like it was turned off. I looked under the hood after trying to get it to run and all I see are 4 small diameter vac lines dangling on the right (passenger) side of the engine. One comes off of a sensor mounted high on the firewall just above the dip stick for the trans. One comes around from behind the carb ending just over the valve cover. One comes off of a valve screwed into the water neck at the front of the engine and the last one comes up from a can bolted to the exhaust pipe just below the tie-in to the ex manifold. The hoses seem to be in good shape but the fittings look like they just melted into hard black plastic. Weird. Can anyone help get these hook up right?
    Thanks /forums/images/graemlins/confused.gif
