vac lines....need some help
Discussion in 'The Garage' started by NEK5, Mar 15, 2006.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    alright i`m replacing the vacum lines hopin to fix my idle problem....and i want to make sure i am gettin them all.....the ones i put in are red.....are there any more i should replace?
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    should be a hard plasitc line with rubber ends running to the map sensor. should at least check that one too.
  3. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    map sensor????? are those the three on the front of the throttle body?
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Should be able to see map etc in this. Don't forget though that there is vacuum lines going inside the cab for cruise release, a/c control etc.
  5. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    i think the ones goin into the cab are fine...they were replaced already i believe...:dunno:.for my 90 is the map sensor in the same place?....when i get home early from school i will check the rest of them and hopefully my idle issue is ressolved
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Should be, mine's a '91.
  7. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    thanks alright i got the problem fixed....all set...the one that went to the EGR valve were junk....but now i have another problem....when i was swapping in the new steering box one of the lines was real bad but didnt leak so we left it...well when i was stepping in the engine compartment i must of step on that because when i turned the truck on to see if the idle was set...and i jumped out i saw fluid on the ground...looked in the engine bay and saw fluid coming out of that aluminum hose and i can feel a crack in it..... :mad: :mad:
