Vac reading at carb
Discussion in 'The Garage' started by Muddytazz, Feb 12, 2006.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Do you always check vacuum on the carb and below the butterflies?
  2. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    Below the throttle plate is where you will get intake manifold vacuum, as oppossed to port vacuum, which is above the throttle plates.
  3. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Call my stupid or having a brain fart here, but throttle plate is in the base plate or the one at the top of the carb?
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The one at the base plate.
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    So really I should take a vac reading off a vac port off the intake, not the carb at all
  6. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    You can do it both ways.
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Reason I say that is cause all my ports on the carb are ABOVE the base plate
  8. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    Are we talking about a Q-jet? All Q-jets have a port connected to the bottom plate. It is usually on the right side of the base plate. It is a large port about 7/16 to 38".
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Nope, holley truck avenger
  10. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Ok, I found the full manifold vac port on the carb
