Vac reading
Discussion in 'The Garage' started by adamforsythe, Feb 27, 2006.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    I hooked a vac gauge up to my carb and I am reading 5 at idel and 15-25 while reving.
    What should I be reading????? School me on vaccum.
    Adam
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you must have hooked it up to the wrong port becasue you should have a higher reading at idle, hook it up to a port that uses vaccum after the throttle plates not before
  3. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    I'll hook it up to the intake this weekend. It's way to cold to do it now. What kind of stuff will the gauge tell you? I know it will tell you if you have a leak ( How ).
    Adam
  4. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
  5. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
  6. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Thanks for the info guys. I think I am smarter when it coes to reading a Vacuum Gauge. :p:
    Adam
  7. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Ive learned the ways of the vacuum gauge and always use 'em to tune carbs. :waytogo:
  8. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    I just hooked my intake up to the gauge and I am reading 20 at Idel and if I gun it it drops down to 5, If I rev up slowly it stayes in the 20-25 range. The gauge does not sway between numbers at idel or if I hold the Rpms off from idel.
    Adam
  9. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    How would i go about adjusting my carb with it????????
    Adam
  10. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Hook up vacuum gauge to a port on carb with constant vacuum. Turn in idle screw to lean it out. Do maybe 1/4 turn at a time. Do this till you get max vacuum. But remember every time your RPM's increase, lower them back down to original idle RPM. You want both idle screws (or 4 depending on carb type) to be about the same. So adjust one then the other, keep going back n forth. 1/4 turn left screw, 1/4 turn right screw... And of course different engines with different cams will have different vacuum readings. If she stumbles fatten 'er up 1/4 turn.
  11. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    You are at 20 at idle, yet after tuning my 388 with cam I never got above 16.
  12. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
  13. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    its a good article.... i guess it pays to save that stuff... my tech folder has gotten quite large.... :haha:
  14. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Sweet thanks for the info.
    Adam
  15. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Trust me i am saving EVERY link.
  16. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Cam selection has a HUGE impact on idle vacuum. Altitude also affects it. Here at 7,000 feet I only get about 13 inches at idle with my 383. :eek1: My stock TBI 350 reads closer to 17 inches.
  17. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Great info guys,thanks...
