Vaccume Advance, full or ported?
Discussion in 'The Garage' started by 78Suburban, Feb 22, 2006.
How should a distributors vaccume advance in my sbc be hooked up?
  1. Ported vaccume source
    54.8%
  2. Full vaccume source
    35.5%
  3. I'm nekkid and vaccume cleaning
    9.7%
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I've heard 2 very different conflicting sources on how my dizzy advance should be hooked up.. So does it need ported (progressive) or full manifold vaccume?
    thanks,
    James
  2. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    Ported, all the way. If it was direct it wouldn't make much sence, why not just add more base timing. It's job it to help out @ part throt. under light loads.
  3. dyeager535
    26,979
    Only difference is what advance you get at idle.
    Manifold will give you more, which tends to help smooth out the idle. Ported will give you almost nothing at idle.
    If it likes ported, give it ported. If it likes manifold, give it manifold. At WOT it doesn't matter, and at cruise it doesn't matter.
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Ported. Like the first post said, full advance all the time is like setting the dist advanced and not using the vac.
  5. dyeager535
    26,979
    Vacuum advance is in addition to mechanical. Advancing dist is not the same thing. 20* of vacuum advance + 8* of mech would be (for instance) 28* at idle. Floor it, you are down to roughly 8* right off of idle since vacuum drops off. Set the dist mechanical to 28* advanced at idle, you START at 28* and just go up from there.
  6. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    This is an article I found and saved. It's a little long, but has alot of good info on ignition timing and what is best for your application. From what I understand, it was written by a GM Engineer.
    "As many of you are aware, timing and vacuum advance is one of my favorite subjects, as I was involved in the development of some of those systems in my GM days and I understand it. Many people don't, as there has been very little written about it anywhere that makes sense, and as a result, a lot of folks are under the misunderstanding that vacuum advance somehow compromises performance. Nothing could be further from the truth. I finally sat down the other day and wrote up a primer on the subject, with the objective of helping more folks to understand vacuum advance and how it works together with initial timing and centrifugal advance to optimize all-around operation and performance. I have this as a Word document if anyone wants it sent to them - I've cut-and-pasted it here; it's long, but hopefully it's also informative.
    TIMING AND vacuum advance 101
    The most important concept to understand is that lean mixtures, such as at idle and steady highway cruise, take longer to burn than rich mixtures; idle in particular, as idle mixture is affected by exhaust gas dilution. This requires that lean mixtures have "the fire lit" earlier in the compression cycle (spark timing advanced), allowing more burn time so that peak cylinder pressure is reached just after TDC for peak efficiency and reduced exhaust gas temperature (wasted combustion energy). Rich mixtures, on the other hand, burn faster than lean mixtures, so they need to have "the fire lit" later in the compression cycle (spark timing retarded slightly) so maximum cylinder pressure is still achieved at the same point after TDC as with the lean mixture, for maximum efficiency.
    The centrifugal advance system in a distributor advances spark timing purely as a function of engine rpm (irrespective of engine load or operating conditions), with the amount of advance and the rate at which it comes in determined by the weights and springs on top of the autocam mechanism. The amount of advance added by the distributor, combined with initial static timing, is "total timing" (i.e., the 34-36 degrees at high rpm that most SBC's like). vacuum advance has absolutely nothing to do with total timing or performance, as when the throttle is opened, manifold vacuum drops essentially to zero, and the vacuum advance drops out entirely; it has no part in the "total timing" equation.
    At idle, the engine needs additional spark advance in order to fire that lean, diluted mixture earlier in order to develop maximum cylinder pressure at the proper point, so the vacuum advance can (connected to manifold vacuum, not "ported" vacuum - more on that aberration later) is activated by the high manifold vacuum, and adds about 15 degrees of spark advance, on top of the initial static timing setting (i.e., if your static timing is at 10 degrees, at idle it's actually around 25 degrees with the vacuum advance connected). The same thing occurs at steady-state highway cruise; the mixture is lean, takes longer to burn, the load on the engine is low, the manifold vacuum is high, so the vacuum advance is again deployed, and if you had a timing light set up so you could see the balancer as you were going down the highway, you'd see about 50 degrees advance (10 degrees initial, 20-25 degrees from the centrifugal advance, and 15 degrees from the vacuum advance) at steady-state cruise (it only takes about 40 horsepower to cruise at 50mph).
    When you accelerate, the mixture is instantly enriched (by the accelerator pump, power valve, etc.), burns faster, doesn't need the additional spark advance, and when the throttle plates open, manifold vacuum drops, and the vacuum advance can returns to zero, retarding the spark timing back to what is provided by the initial static timing plus the centrifugal advance provided by the distributor at that engine rpm; the vacuum advance doesn't come back into play until you back off the gas and manifold vacuum increases again as you return to steady-state cruise, when the mixture again becomes lean.
    The key difference is that centrifugal advance (in the distributor autocam via weights and springs) is purely rpm-sensitive; nothing changes it except changes in rpm. vacuum advance, on the other hand, responds to engine load and rapidly-changing operating conditions, providing the correct degree of spark advance at any point in time based on engine load, to deal with both lean and rich mixture conditions. By today's terms, this was a relatively crude mechanical system, but it did a good job of optimizing engine efficiency, throttle response, fuel economy, and idle cooling, with absolutely ZERO effect on wide-open throttle performance, as vacuum advance is inoperative under wide-open throttle conditions. In modern cars with computerized engine controllers, all those sensors and the controller change both mixture and spark timing 50 to 100 times per second, and we don't even HAVE a distributor any more - it's all electronic.
    Now, to the widely-misunderstood manifold-vs.-ported vacuum aberration. After 30-40 years of controlling vacuum advance with full manifold vacuum, along came emissions requirements, years before catalytic converter technology had been developed, and all manner of crude band-aid systems were developed to try and reduce hydrocarbons and oxides of nitrogen in the exhaust stream. One of these band-aids was "ported spark", which moved the vacuum pickup orifice in the carburetor venturi from below the throttle plate (where it was exposed to full manifold vacuum at idle) to above the throttle plate, where it saw no manifold vacuum at all at idle. This meant the vacuum advance was inoperative at idle (retarding spark timing from its optimum value), and these applications also had VERY low initial static timing (usually 4 degrees or less, and some actually were set at 2 degrees AFTER TDC). This was done in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it.
    If you look at the centrifugal advance calibrations for these "ported spark, late-timed" engines, you'll see that instead of having 20 degrees of advance, they had up to 34 degrees of advance in the distributor, in order to get back to the 34-36 degrees "total timing" at high rpm wide-open throttle to get some of the performance back. The vacuum advance still worked at steady-state highway cruise (lean mixture = low emissions), but it was inoperative at idle, which caused all manner of problems - "ported vacuum" was strictly an early, pre-converter crude emissions strategy, and nothing more.
    What about the Harry high-school non-vacuum advance polished billet "whizbang" distributors you see in the Summit and Jeg's catalogs? They're JUNK on a street-driven car, but some people keep buying them because they're "race car" parts, so they must be "good for my car" - they're NOT. "Race cars" run at wide-open throttle, rich mixture, full load, and high rpm all the time, so they don't need a system (vacuum advance) to deal with the full range of driving conditions encountered in street operation. Anyone driving a street-driven car without manifold-connected vacuum advance is sacrificing idle cooling, throttle response, engine efficiency, and fuel economy, probably because they don't understand what vacuum advance is, how it works, and what it's for - there are lots of long-time experienced "mechanics" who don't understand the principles and operation of vacuum advance either, so they're not alone.
    vacuum advance calibrations are different between stock engines and modified engines, especially if you have a lot of cam and have relatively low manifold vacuum at idle. Most stock vacuum advance cans aren't fully-deployed until they see about 15" Hg. Manifold vacuum, so those cans don't work very well on a modified engine; with less than 15" Hg. at a rough idle, the stock can will dither in and out in response to the rapidly-changing manifold vacuum, constantly varying the amount of vacuum advance, which creates an unstable idle. Modified engines with more cam that generate less than 15" Hg. of vacuum at idle need a vacuum advance can that's fully-deployed at least 10", preferably 2" of vacuum less than idle vacuum level so idle advance is solid and stable; the Echlin #VC-1810 advance can (about $10 at NAPA) provides the same amount of advance as the stock can (15 degrees), but is fully-deployed at only 8" of vacuum, so there is no variation in idle timing even with a stout cam.
    For peak engine performance, driveability, idle cooling and efficiency in a street-driven car, you need vacuum advance, connected to full manifold vacuum. Absolutely. Positively. Don't ask Summit or Jeg's about it, they don't understand it, they're on commission, and they want to sell "race car" parts.
    Take that for what it is worth. I have tried both variations, and I prefer ported on the 388 in my Burb.:D
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    My engine likes full vacuum. At idle it has almost 30deg of advance:eek1:
    Try both and give the engine what it wants.
  8. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    Wow... so maybe I DO need full advance.. I can hook it into that I guess.. I've tried both ways, and my burb isn't really doing good with either... I never knew there was such a big controversy about which source to use... hmm.. this throws another possible factor in... all that being said, I don't think using either source is gonna radically alter how my motor runs... cause its running like CRAP.
    thanks,
    James
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Mine likes ported , the 305 in the DD with all the smog stuff . It does idle at 550 rpm in gear without stalling , even on its side ( off camber ) , but doesn't run over 195 on a hot day in AZ :D
  10. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I DUNNOOOOO, my computer does all this for me :D :haha:
  11. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Have you ever looked at what the timing was with that stupid brown wire not disconnected?
  12. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    he'd know if it was anything other than 0*. Even 2* advanced and it runs like crap in my experience.
  13. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    wired up a tach
    it idles at 600 rpm with full manifold vaccume. it idles at 450 with ported vaccume. I'm starting to wonder if BOTH carbs I've tried havent' been incorrectly tuned.... Is there any way that a manual choke edelbrock performer 600 could have the choke disenguaged, but still have something in the choke linkage causing tons of fuel to dump into the engine? or do I just have to fiddle with metering rods and idle mix screws if it is in fact the carb?? could the carb have some bad internal problem from sitting un ran for a year? if so, should I tear it down and check for something (I've never had a carb apart). Any more ideas are more than welcome.
    thanks,
    James
  14. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    Ported....full...??
    My 86 305 from a G-10 runs best with full manifold advance..it was originally equipped with a Q-jet and a ESC type HEI,which I removed and replaced with a 76 305 HEI with vacuum advance and an edelbrock performer 600 carb..
    I tried ported vacuum,and it pinged under load and at highway speeds on hills..not severely,but enough so I didn't like it..does not ping at all using manifold vaccuum,and idles much smoother too,has more pep and gets a bit more MPG on "around town" trips..no EGR hooked up either,the edelbrock hits the EGR valve on an OEM Q-jet intake,so it had to be removed..
    Just about all the other chevy's I've had used ported vacuum,and seemed to run best that way if I tried switching the vacuum source..
    78 suburban,your carb could be gummed up or dirty from sitting,causing the float needle valves to not seat completely and let it flood some..or the float level might be too high...it could be its jetted too rich,but I'd check all the basics first,including and vacuum leaks between carb and intake(especially if you used an adapter,or are "mixing" brands,like a Edelbrock carb,and a stock GM or aftermarket intake ..if you did not wire the choke open,it might be closing by itself,it will if you leave the linkage dissconnected and don't secure it somehow..:crazy:
  15. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    How can I check for this, I've never torn into an edelbrock, but If I knew how to and what I was looking at, I would be out there right now in the rain tearing to that sob before college :bow: Well, I gotta go to school, but Friday I'm gonna try to work on it all day, it will be my last chance to get it running by some MIRACLE, before the mud bog of Saturday Night..
    thanks,
    James
  16. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    watch closely...
    With the motor running,look down into the carb air horn with the air cleaner lid off, and watch,gas should be spraying in a fine mist down both front barrels,not pouring in like a faucet,or dribbling out in large drops....usually if its flooding you'll know right away..it will belch black smoke out the exhaust,idle roughly and load up,and stall if its flooding badly enough..and choke you,and bring tears to your eyes,especially when you watch your wallet shrink like a deflating ballon from all the gas your wasting!..:(
    Try using some carb cleaner spray ,and add a bit of liquid carb cleaner to the gas thank too,before attempting to take the carb apart,especially if it ran ok before being parked..it might just be some gummy crud blocking the air bleeds in the top of the carb,or the floats needle valves a little sticky from gummy fuel...
    Edelbrock has a good website with plenty of exploded diagrams and tech info, at www.edelbrock.com
    The performers are pretty basic carbs to work on,one of the simplest ones really..I've always liked them,and the Carter AFB's they were derived from..they are very fussy about carb icing in the colder and wet weather though,much more so than many others I've had..if you can rebuild a Q-jet,an edelbrock is a peice of cake..
    The idle speed will change depending on which source of vacuum is used...ported gives no adavance at idle...switching to full (manifold) vacuum will cause the engine to idle faster,advancing the timing can affect idle speed quite a bit.. ..so you'll have to re-set the idle mixture and speed depending on the source of vacuumm..maybe the base timing too..(set that with the vacuum advance disconnected and the hose plugged)..:crazy:
  17. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    So can I just spray carb cleaner into the carb as the motor is running??? how exactly should I use the cleaner, I have a whole can.... if there is a way to use it to cure my problems, I wlll crap a golden egg and be happy forever more :bow: :bow:
    thanks,
    James
  18. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    I have always gone with ported vacuum because it brings in timing advance faster for better off the line acceleration.
  19. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    How can that be any faster then all in at idle?
  20. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    You know, I typed out a full reason for why I do this, and then I said F*CK IT! I am tired if defending myself for every little thing I post around here. I just do it because it works!
