vaccume leak ????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NoSmog73, Feb 3, 2002.
  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Ok here goes I put my foot on the brake and (out of gear) idle goes up (thought was check valve so I replaced no luck) but when cold come to stop in gear and It will idle way down to about 200 and then die if I dont get it into neutral. I will change the booster but anything or area that I can check (beside the usual vaccume lines on the carb maybe) thanks for any thoughts or tips again thanks later-mike
  2. dyeager535
    26,977
    don't throw the booster, they aren't hard to check. Start truck, don't touch the brake, let run for a few seconds. Turn truck off. Wait 45 minutes. Go back to truck, don't start it. Pump brakes. You should have 2 or 3 ASSISTED brake applies, before the pedal effort gets harder. A lot cheaper than replacing a booster that might be fine.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  3. Grim-Reaper
    7,385
    Atlanta
    A lot of times when a booster goes bad you can hear them sucking. Now they will make a noise when you first press the brake but once held they should be quiet. if you hear a sucking noise while holding it steady, it's bad. Then not holding vac is sualy the check valve but can also be a cracked diaphram. Do the test as descibed in the other post And listen for the sucking noise.
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  4. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    thank you for the info will try this weekend??
  5. rain1971
    rain1971 Registered Member
    Feb 2, 2002
    50
    canada (7 hours from seattle washington)
    I just bought 2 blazers, and on the one i decided to fix up, the brakes were terrible, i checked disc pads and they were very good still, so i thought, "master cylinder" so i changed it, no luck, then because i had the parts truck here anyways, i changed the vacuum booster, still no luck, now i know it is the calipers are sticky, wish i had read this post a month ago . :)
    Theres no replacement for displacement!
    I want a big block!
