vaccume mod ??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NoSmog73, Jul 14, 2002.
  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Ok if I put it in reverse and back out of the drive I get to the bottom and it isn't in gear then after I stop and tap the gas it will go into gear....Is that a clue that the modulator is going bad or time for a rebuild....
    It isn't the linkage because sometimes I try to put it into drive (when it doesn't go into rev)and the same thing happens...mike /forums/images/icons/smile.gif
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Is your ATF topped off?
