vacum chaos i need help
Discussion in 'The Garage' started by TC4x4, Sep 17, 2006.
  1. TC4x4
    TC4x4 1/2 ton status
    Sep 12, 2006
    831
    Michigan
    I am replacing my carburator and am wondering if i have to keep the coffee can like thing in my 84 blazer, it has all thoes black tubes running from it which i think are the vacum can i take that stuff oout and unclutter my engin or what?
    Thanks the Mule
  2. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    It is a vaccume reservoir. I think mostly for the AC blend door operation.
  3. Rescuedad77
    Rescuedad77 Registered Member
    Sep 14, 2006
    17
    Bellevue NE
    I had an 81 blazer and took out the a/c and those vaccum lines and it ran fine.
  4. dyeager535
    26,975
    Coffee can shape piece is EVAP.
    You can remove it, although it's illegal and costs nothing in power, if anything it may help economy a hair.
    The critical part is the tank vent line. You've got to vent the gas tank somehow, venting it in the engine bay IMO is a bad idea.
  5. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    the thing that looks like a coffee can is not evaps. it is only a reservoir for holding a constant vacume pressure. there is a charcoal canister in there also but it has multiple
  6. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    the thing that looks like a coffee can is not evaps. it is only a reservoir for holding a constant vacume pressure. there is a charcoal canister in there also but it has multiple larger lines and a
  7. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    the thing that looks like a coffee can is not evaps. it is only a reservoir for holding a constant vacume pressure. there is a charcoal canister in there also but it has multiple larger lines and only one vacume line to the solenoid. usually down by the front bumper if I remember.
  8. dyeager535
    26,975
    AFAIK EVAP cannister is mounted to the drivers side of the core support. Poster will have to clarify which piece/location he is talking about. I've never seen a vacuum reservoir on the trucks, (cars were round though) doesn't mean they don't exist. :)
  9. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    the vaccume reservoirs used to look exactly like a coffee can untill they went to the 4" round plastic ball type.
