Vacumm Advance 81 K5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Trailblzn, Nov 5, 2003.
  1. Trailblzn
    Trailblzn Registered Member
    Feb 26, 2002
    41
    Northern, CA
    I am getting conflicting info on wether or not my truck should have vacumm to the distributor at idle or not. I changed the vacumm switch on the thermostat housing and now the vacumm advance has no vacumm at idle. Any ideas. The motor runs rough just off idle.
  2. dyeager535
    26,979
    Most trucks were set up with no vacuum at idle. Not all, but most. I would *speculate* all K5's your vintage were, based on the emissions class.
    All you did was change the switch? Are you sure you got the right one?
  3. Trailblzn
    Feb 26, 2002
    41
    Northern, CA
    Yes the part number matches the old switch, I'm not sure why it runs rough just off idle.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    well, it depends, theres no solid answer, it really depends on how it runs with it either connected to full, or to part time, i alays connect mine to part time, but have run into one 350 engine that would not run right with part time, or even with advance even connected at all.
    each engine is different really.
    i would time engine with vacuum guage set it for 18-22 inches of mercury at idle(if is stock cam), i dont even use a timing light ever and i get mine so fine tuned with vacuum guage that you can stand outside of truck and reach in and flip key switch real quickly and will fire right up split second just like its fuel injected. i only run stock Q jets and stock HEI distributors for this reason
    good luck
  5. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    Are you sure You didnt create a vacum leak? or mix up the hoses ?
