Vacumme to vent system on 89' Burb?
Discussion in 'The Garage' started by AZ_Overdrive, Feb 6, 2004.
  1. AZ_Overdrive
    AZ_Overdrive 1/2 ton status
    Dec 18, 2002
    117
    Arizona
    Vacumme to vent system on 89\' Burb?
    OK, I tore into my vent system and replaced the "guaranteed" broken plastic vent clip on the vent - heat/defrost door. I took some advice from others here and purchased three of them!
    Here is my problem. It appears there is no vacumme in any of the lines that control the various valves on the distribution box. I checked the fresh air (passenger kick pannel) and the heat/defrost vacumme valves and the lines are there but when I move the switch from A/C, vent, heat, defrost none of the baffeles move. I kept the glovebox and vent/heat cover (the one to the right of the trans hump) off so I could see any movement, but nada. The manual control (cable) for hot/cold works fine.
    Any ideas on were to start looking for why there may be no vacume reaching those valves?
    Thanks for any info.
    /forums/images/graemlins/burb.gif
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Re: Vacumme to vent system on 89\' Burb?
    Take a quick peek at the tiny plastic line in the engine bay, coming thru the firewall just above the ECM's hole. Make sure its connected to a good vacuum source. /forums/images/graemlins/thumb.gif
    -Dan
