Vacuum Advance
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by josephn, Nov 20, 2000.
  1. josephn
    josephn 1/2 ton status
    Nov 3, 2000
    138
    Utah
    Should you connect the vacuum advance on the distributer?
    Are there any problems with not having it connected?
    Joe.
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    If it is not connected, then the "Vacuum Advance" wont work.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    <font color=blue>If it is your stock distributor and motor, then you should leave it connected. If not you will lose performance, part throttle gas mileage and driveability. You would lose performance until all of the mechanical advance has kicked in (probably @3000-3500 RPM'S, not sure exactly), and your gas mileage, as it is not running properly at part throttle, or until all of the advance kicks in. Bottom line, more than likely you would lose power off of the line. You could up the initial advance to the point (when you set the timing, and then you plug in the vacuum advance, the line jumps way up) where the timing line is at (what I said just previous). But I would not recommend this for a stock application, and I don't know why anyone would want to do this, except maybe on a high performance motor. - Steve</font color=blue>
    <font color=blue>Steve Sosa a.k.a. "sosaman"</font color=blue>
    http://sosaman.home.texas.net/carpics.html
  4. josephn
    Nov 3, 2000
    138
    Utah
    Thanks,
    The question was for my brother in law who just bought a new truck that didn't have it connected and I wasn't shure why they would have disconnected it. He has been complaining about his gas mileage so maybe this will help.
    Anyway thanks again.
  5. LAZYMON
    LAZYMON 1/2 ton status Premium Member
    Jul 26, 2000
    235
    Lake Tahoe
    You disconnect it to set timming and they probably forgot to reconnect it
    Topless73
  6. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    There are three kinds of advance. Mechanical advance, controlled by springs and weights inside the distributor. Vacuum advance, controlled by engine vacuum through a vacuum line. Initial advance, controlled by how much you turn the distributor before you tighten the hold-down nut.
    When you set timing, you disconnect the vacuum advance and a tech probably forgot to reconnect it.
    -- Mike
  7. josephn
    Nov 3, 2000
    138
    Utah
    Thank for your answers. You guys rock.
  8. CAPTAINK5-CT
    CAPTAINK5-CT 1/2 ton status
    Sep 10, 2000
    124
    CT, USA
    Mine went bad and caused the truck to hesitate on pulling away from stops (scary at busy intersections). Had my mech fix it and all is well.
