Vacuum can in cowl
Discussion in 'The Garage' started by DwarF, Sep 17, 2004.
  1. DwarF
    DwarF 1/2 ton status
    Mar 29, 2001
    226
    Austin, Tx
    There is a vacuum canister inside the cowl. Not in the engine compartment, not in the cab, and not under the truck, but inside the cowl on my 1983. What is this for?
  2. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    It closes the plenum valve when the Max A/C setting is selected, thus not allowing outside air in. When this valve closes the valve in the RH kick panel opens allowing the bolwer to take air from inside the cab.
  3. DwarF
    Mar 29, 2001
    226
    Austin, Tx
    Thanks mosesburb.
    Does anyone have a diagram of the vacuum hose hookups?
