Vacuum Diagram
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by porboy, May 7, 2002.
  1. porboy
    porboy Registered Member
    May 7, 2002
    29
    Poway Ca.
    I just put a new 350 crate motor in my 75 suburban. In my hurry to get the new motor in I forgot to label all my vacuum lines. THere aren't many but I don't want to mix them up. If any body has a diagram and could help me out I would greatly appreciate it.
    By the way I am running a 4mv quadrajet carb and the distibutor has the vacuum advance. Thanks in advance.
    Jason Gutzmer
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    You only need three lines to be honest. Your vacuum advance should be hooked to the port on the carb that won't suck at idle, but when you rev it, you can feel vacuum. There is a line on the back of your air cleaner that controls a flap that lets in warm up for cold days. It should be hooked up to a source with constant vacuum, usually the tree behind the carb. PCV valve is pretty much a no brainer, a big port that fits the hose. If you have cruise, then that line also gets full vacuum. Just start it with the hose plugged and then pull out the plug and feel for suction and an idle speed change.
