Vacuum gauge
Discussion in 'The Garage' started by jagerman, Mar 3, 2007.
  1. jagerman
    jagerman Registered Member
    Feb 12, 2007
    6
    here
    What is the use of having a vacuum gauge?
  2. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    keeping the engine at maximum vacuum saves fuel. Its a way of making yourself stay out of the skinny pedal.
  3. sweetk30
    Nov 1, 2004
    25,540
    539
    horseheads , ny 14845
    x2 i got one and it works. when haullin the big trailer. i figured it was good in top gear. but installed the vac gauge and found out it was bad . no vac in top gear. drop to a diffrent and bam perfect.
    play with it a bit and also find that to cruise you dont need as much pedel to stay the same speed as before.
  4. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    i use mine so i know when i have brakes :D
    Scary part is thats kinda true.
  5. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    A Vac gauge can tell you a lot about how your engine is running as well.
