Vacuum injector pump?
Discussion in '1982-Present GM Diesel' started by Tybee, Aug 18, 2002.
  1. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    On the passenger side of the injector pump there are vacuum lines on my 84 there are wires. Will this work on my 84 can I change out the vacuum stuff with my electrical? What year is this from?
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Do the lines go into the pump? Or are you referring to the vacume switch on the linkage? /forums/images/icons/confused.gif
  3. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    I'm not quite sure what you're asking. You must have a spare pump that you're looking at?
    The 6.2L with a TH400 behind it utilizes a vacuum controller mounted on the right side of the pump to help control shift points.
    The 6.2L with a TH700R4 behind it utilizes a TPS mounted on the right side of the pump which controls TC lockup.
    Both of these devices are different and have different functions and are not interchangeable.
    However, both devices are just bolted to the pump, so they can be removed and placed onto another pump.
    Casey
  4. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    [/ QUOTE ] That would be it. Thankyou
