Vacuum leak on my 89 Burb, below the tbi (TPS sensor)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Jul 9, 2003.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Ok... let me cover what the engine is real quick... its a 96 short block, with L31 heads, Edelbrock Performer intake (spreadbore), and a L98 roller cam. I've got an adapter to go from spreadbore to TBI, which fits great. The problem is, there seems to be a MASSIVE vacuum leak below the TPS (the sensor that is in the passenger, front of the TBI.) I can hear it leaking, and when I spray it with carb cleaner while its running, it nearly chokes out the engine.
    There is a new gasket installed, and both surfaces were clean when it was installed. Goofy thing about the gasket is... it would appear that its not supposed to cover this area of the TBI. Which I can't figure out. /forums/images/graemlins/confused.gif
    HELP! PLEASE! /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/eek.gif
    -Dan
  2. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    /forums/images/graemlins/confused.gif ttt /forums/images/graemlins/confused.gif
  3. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I bet I know your problem. Did your adaptor have the holes drilled and tapped for mounting the throttle body either backwards or forward? If so, check the extra bolt holes, they will leak if not plugged. Use 5/16"-18 x 1/4" long socket head set scews and locktite them in place. /forums/images/graemlins/thumb.gif
  4. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    AH HA! Right you are sir! As a matter of fact, there are two different bolt patterns in the adapter... I think you might just have the answer there! You da man Neil! I'll take a look at that tonight.
    _Dan
