Vacuum leak
Discussion in 'The Garage' started by Topdown, Dec 28, 2004.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Ok...
    Once again I seem to have a vacuum leak.
    I am running a 72 K5, TH350 trans, 350HO Deluxe crate motor around a year old, (maybe less), Q-jet...
    it idles like crap... tries to die when I get to stop lights. cold, warm, etc... idles like crap. I dont think my secondaries are opening either, but thats probably because the leak is bad enough that it wont pull then open. When I cup my hands over the carb it idles up like its choked so its sucking air from somewhere.
    I have tried starting fluid... it either isnt working for me or I have a vac leak on ever hose end, the base of the carb, the entire intake manifold, etc... I am leaning toward that method isnt working for me.
    thoughts? Help? Anyone want to come fix it for me for beer and pizza?
  2. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Could be leaking from under the intake in the lifter valley. Make sure the carb is bolted tight and your one way valve on the power booster for the brakes is operating correctly.
    Take a mechanics stethascope remove the probe so the open hose is left and run it across any area that could be leaking.
    Is this a consistant issue? Like it keeps poping up? Is it all the time or only warm?
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    connected a shop vacuum guage yet ?
    sound slike idle circuit may be fudged in the carb, unless timing is retarded too much
    check these things, let us know what timing and vacuum settings youre running
    good luck
  4. rerun93
    rerun93 Registered Member
    Dec 3, 2004
    98
    chico, ca
    does the exhaust smell rich of fuel?
  5. Topdown
    Nov 26, 2002
    2,598
    constant
  6. Topdown
    Nov 26, 2002
    2,598
    I dont know if the exhaust smells rich or not, I dont remember taking the time to smell it.
  7. Topdown
    Nov 26, 2002
    2,598
    timing is set @ 10, was set before the issue started and is still sitting there. No idea on the vacuum setting yet
  8. Topdown
    Nov 26, 2002
    2,598
    just another tidbit... I cant pull off vac hoses and create a vac leak that causes the truck to run worse. Just another indicator that its a vac leak
  9. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    I say take a vac. reading at manifold port...
  10. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    vac leak info
    if you have a friend in the auto biz ask him to use the new smoke machine. 3-4 companys sell them man do thay work. we have one at work. you can check coolent ,vac, leaks and exaust leaks just about anything you can think of . the other day i did a p/s leak and found it up under the motor were i couldnt see it . what a time saver.
  11. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    If you have a vacuum advance distributor, make sure that the advance diaphragm isn't ruptured. I spent over a year searching for a small vacuum leak and was I shocked when I finally found it on the vac advance line...... :mad:
  12. Topdown
    Nov 26, 2002
    2,598
    ok...
    I have replaced every vac hose on the truck now. (including the line down on the tranny)
    unhooked the trans and power brake booster lines and plugged them to test ... still have the problem. I am going to pull off every line and plug all the holes tomorrow morning. If I still have the leak, its a manifold leak.
    As it sits right now, when I spray starter fluid on the driver side intake/head the RPM increase. if I hold it and spray lots, the RPM increase more. So, I am guessing that its a manifold leak.
