Vacuum leak?????????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PGL4VT, May 6, 2002.
  1. PGL4VT
    PGL4VT Registered Member
    Feb 10, 2002
    71
    Roanoke, Virginia
    91 K-5. My cruise control won't hold on hills anymore and my climate controls don't work properly anymore. I put it on defrost and air blows from the dash vents and floor. I put it on floor and it blows from all places. Also, the truck idles fine but when I stop at a light and it's in drive, the idle becomes really rough. Vacuum leak? Ideas? Anyone had this happen? Thanks.
    91 K-5
    72 K-5
  2. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    I don't have the cruise but I would check (on mine at least) there is a vaccume port screwed into the back of the intake right behind the carb in front of the dis. I would check all the main vaccume lines that go to the components that are messing up ( they might even tie into the same vaccume port)...mike
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    It sure sounds like a vacuum leak to me. Espescially when you mention the flappers under the dash not working right. Get a can of carb cleaner and start spraying around. Be careful around the distributor, I burned my eyebrows off once!!
  4. mlb79
    mlb79 Registered Member
    May 24, 2001
    40
    evansville, IN
    I'm not sure about the 91, but on my 79 there is a small piece of vacuum hose on top of the blend box. The hose is kinda tough to get to unless the blend box is out of the truck. Mine was dry rotted and leaking badly, it is connected to a diaphram. The 91 may be very different, at least now you know there is one hiding.
