Vacuum line on rear of intake manifold on 87 TBI
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wolfy87, Feb 5, 2004.
  1. wolfy87
    wolfy87 Registered Member
    Jan 30, 2004
    32
    near Dallas, TX
    Alright, this is the latest episode on my painstaking troubleshooting of my low rpm/ underload stumbling. Last night I was checking and rechecking all the vacuum lines. I found that the hose coming from the intake directly behind the throttle body was running astray and not plugged into anything. Can't see it being a free outlet vent tube. Since Chilton was kind enough to include a vacuum line diagram for every year truck EXCEPT the 87, /forums/images/graemlins/angryfire.gif I was stump-ed. /forums/images/graemlins/confused.gif The previous carbed years all seemed signifigantly different and its an 80-87 book. Darn greedy Chilton slackers. The lack of detail in those books would even make it hard to work on Fred Flinstone's car.
    Anyone know where that hose should be routed? Looked like there was a vacant inlet on the EGR diaphragm, but the hose didn't seem to mate up to that real well. The end of this hose has a little micro-funnel inserted into it. /forums/images/graemlins/1zhelp.gif
  2. dyeager535
    26,975
    Maybe other TBI truck guys can comment, but I would imagine your truck is supposed to have an EGR solenoid...vacuum line from motor somewhere, to solenoid, then hose from solenoid to EGR valve.
    If the solenoid isn't hooked up, thats probably where that line used to go, although the "funnel" thing has my confuzzled.
  3. conoverbandit
    conoverbandit 1/2 ton status
    Jan 23, 2002
    452
    Conover N.C
    Hello,
    By no means a "pro" at this but I'm having problems with my TBI also, I have a 87 454 truck and the only vac. line comming out of the rear of TBI runs over to the left of the engine( standing in front of truck look towards firewall) and hooks to a small box that has only one vac. line input and a 4 wire plug on top of it. Look there and see if that's where it goes, the other one on front of TBI center goes to the "purge" on canister, right side goes to a small black box at the font of the engine and then from there to the EGR, the one on the left of TBI goes to the A.I.R selinoid for air injector pump I found this on just laying around in engine compartment lol. But like I say this is how mine runs on a 87 454 TBI #220 yours may be different, but maybe this will give you a baseline to work from. Hope it helps.These are from TBI it's self, I can look on intake if you'd like and try to get you a diagram.Just let me know.
  4. detailer03
    detailer03 1/2 ton status
    Sep 23, 2003
    108
    Arizona
    OK, If I am not mistaken, on my 89, it goes to the firewall. There is a Tee there. It is for your vacuum operated stuff in the cab.
    I am at work now, and will check later.
  5. Grim-Reaper
    7,385
    Atlanta
    sticker missing on the coresuport? it should list where the lines go.
    The one on the actuall intake is the feed line for cruise and the HVAC. The brake booster also ties in from the back. You may also have a water coolant line that often gets left off and by passed because the line is dealer only and $70.
    The EGR on mine feed off the front of the TBI unit. There is 4 connections, EGR, PCV,EVAP, AIR
  6. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    On my 1987 350 TBI, there was one vacuum line in the back of the throttle body and three in front. the one in back went to the MAP sensor, and in the front, one went to the the A.I.R. diverter valve, one to the purge canister and one to the EGR valve, if I remeber correctly. I have had the big block in for about 9 months so it cant rember exactly with the SBC...
    Chris
  7. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    just checked tags on mine, both sb and bb rear vac line goes to map sensor.
