vacuum line question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by caryhenry, Dec 11, 2002.
  1. caryhenry
    caryhenry Registered Member
    Sep 28, 2002
    78
    Tallahassee, Fl
    I am in the process of removing any unneccesary vacuum lines, and my question is this: if I remove the vacuum lines which do not affect the main components, do I still need to cap off these lines?
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    Yes, cap off everything that is not running to something. Otherwise it is a vacuum leak that can cause weird idling or strange operation of the other components that are still hooked up.
    What are you thinking of removing?
  3. caryhenry
    Sep 28, 2002
    78
    Tallahassee, Fl
    where can I buy caps for the vacuum lines?
  4. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    At Office Depot, they're called binder clips, some folks use golf tees. What you should do is trace the line back to the manifold or carb and pull it off. Then cap the nipple that you just pulled the line off of. Kragen has these caps, called vacuum caps(whoa) /forums/images/graemlins/smirk.gif. They're in the section with the HELP! stuff or with the hardware that comes in the blister pack. hope this helps. /forums/images/graemlins/usaflag.gif
