Vacuum Line Routing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stoopalini, Mar 14, 2005.
  1. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    I am in process of installing a built motor in the Blazer. I am putting a Rochester Q-Jet on in place of where a Holley 600 used to be.
    The only vacuum lines I see are Vacuum Advance, Brake Booster, Vacuum Reservoir, Transmission (TH350), and a line going through the firewall. Am I missing any here?
    Can someone please tell me what ports these lines go to on the carb, or intake? I'm using an Edelbrock Performer dual plane which has a T style standoff for vacuum at the rear of the intake. I'm pretty sure the tranni line goes to this T directly on the manifold, but am not sure.
    Thanks for any info,
    Thomas.
  2. dyeager535
    26,980
  3. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Thanks Dorian, this will help.
    Just need to decipher what is still on the motor, since there's no EGR, air pump etc ... and I'm running an open element air filter.
    Thomas.
